Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 63
Thread: Anyone interested in YACS?
  1. #21
    AutoTouch Creator Gremlin's Avatar
    Nov 2003
    Seattle
    No, I didn't...
    And I just realised that a rename error caused that newer version (not the debug, the regular version) to be put in the wrong place, so when I asked folks to download the better error reporting version they got the same one. I'm finding a machine without VS2003 on it now, and I'll try that! Thanks for the idea Satish.
    -G
  2. #22
    Nov 2003
    Seattle
    Okay now I tried...
    Please try the latest version and let me know what error it generates. I tried this on a machine without visual studio. In fact it was a brand new Dell, I had to install Map Point 2004, and run it once before I could use my app, but then it worked just great.
    I'd like to know if the now renamed version on the web site or the Debug version gives any other information.
    -G
  3. #23
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Failed to initialise the Navigation Form.
    Do you have MapPoint 2004 Installed?
    Have you set the correct Map in the skin.xml file?
    System.Runtime.InteropServices.COMException (0x800A400E): MapPoint North America can't run because it is not registered on your system, or it can't be found. Install MapPoint North America and try again.
    at MapPoint.IMappointCtrl.NewMap(Object Template)
    at AxMapPoint.AxMappointControl.NewMap(Object template)
    at CarInterface.NavigationForm..ctor(ControllingForm control)
    at CarInterface.ControllingForm..ctor()
    Stack Trace
    <?xml version="1.0" encoding="utf-8" ?>
    <AutoTouchSkin>
    <Main>
    <name>Monaco Brown</name>
    <background image="MBSkin\composited main.png" color="111,88,63"></background>
    <HotSpots nav="267,0,264,192" music="568,168,264,256" dvd="8,171,216,256" system="328,232,144,136"
    settings="267,400,264,248"></HotSpots>
    <foreground color="255,255,255"></foreground>
    <UpArrow image="SelectUp.png"/>
    <DownArrow image="SelectDown.png"/>
    </Main>
    <DVD>
    <application path="C:\Program Files\REALmagic\REALmagic Hollywood Plus\station.exe"></application>
    </DVD>
    <Music>
    <background image="MBSkin\music.png"></background>
    <shuffle image="MBSkin\Glowing Shuffle.png" pos="569,474"></shuffle>
    <HotSpots album="208,8,160,144" artist="16,8,160,144" playlist="416,8,160,144" Next="400,480,152,112"
    Prev="0,480,152,112" Clear="632,8,160,144" Home="712,504,80,80" Shuffle="568,480,128,112"
    PlayPause="184,480,192,112"></HotSpots>
    <AlbumImage rect="32,216,200,200"/>
    <ArtistsName rect="248, 240,528, 48"/>
    <AlbumName rect="248,344,552,40"/>
    <TrackName rect="248,288,520,56"/>
    </Music>
    <Navigation>
    <background image="MBSkin\navigation.png"></background>
    <MapPointRegion>Europe</MapPointRegion>
    <HotSpots zoomin="16,520,80,72" zoomout="120,520,80,72" menu="312,528,240,64" home="704,504,88,88"></HotSpots>
    <NavArrows Straight="MBSkin\Straight Arrow.png" VeerLeft="MBSkin\Veer Left.png"
    Left="MBSkin\Left Arrow.png" VeerRight="MBSkin\Veer Right.png"
    Right="MBSkin\Right Arrow.png"></NavArrows>
    <NavOptions Rotate="false"></NavOptions>
    </Navigation>
    </AutoTouchSkin>
  4. #24
    Nov 2003
    Seattle
    Okay that's odd, when I use your XML file it tries to load the european map, can you make sure that the file you changed is called "Skin.XML" in your run directory? It's weird because it says' it's using North American in the stack trace!
  5. #25
    Nov 2003
    Seattle
    Okay, there's now a new build up there that will automatically try for both maps. As long as you have MapPoint 2004 it should work just fine. Please let me know if there are further difficulties. I have posted both a release and a debug version.
    -G
  6. #26
    Nov 2003
    Seattle
    More information
    Because of a bug in my setup app it installs and then removes wmp.dll from the autotouch directory. This of course is the wrong thing to do. So I've fixed it now, but if uninstalling AutoTouch makes your windows media player 9 stop working do the following in a command prompt:
    cd \windows\system32
    regsvr32 wmp.dll
    this should start it working again, apologises for that screw up. And please continue to let me know if it works for you at all! I'll be putting a new install up this evening that takes care of this issue (I can't do it from work)
    -G
  7. #27
    Nov 2003
    Seattle
    Okay new version is up on http:\\www.sarinarts.com/autotouchsetup.msi
    Please more feedback!
  8. #28
    Nov 2003
    Seattle
    And now I have a web site with screen shots www.sarinarts.com\autotouch.htm
  9. #29
    Oct 2003
    Madrid
    I get this error when I try to select anything in music or try to route!
    Can you make it default to a font that comes with Windows?
  10. #30
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Quote Originally Posted by Laidback
    Open the skin.xml, look for the 'Bold' in the font attribute and remove it. That'll help.
    You also may change the font used to let's say "Arial, 26pt".
    BTW: The easiest way to edit such XML configuration files is to use a XML editor. If you don't have such, you can get the XML Notepad from MS. It's no longer supported by MS itself but you'll still find it here for download:
    http://www.webattack.com/get/xmlnotepad.shtml
    Skinning to go... VisualDesigner2!
  1. Anyone interested in touchscreens?
    By e_fractal in forum Input Devices
    Last Post: 04-05-2004, 09:08 AM
  2. Anyone interested?
    By orangewhip in forum Classified Archive
    Last Post: 09-15-2002, 08:15 PM
  3. Still interested in Arby's service
    By psychoman in forum Off Topic
    Last Post: 08-14-2002, 10:34 PM
  4. Also interested
    By Nos in forum Classified Archive
    Last Post: 07-24-2001, 10:20 AM
  5. I'm interested...
    By Chlor in forum General Hardware Discussion
    Last Post: 02-20-2001, 11:48 PM
