Upon doing a, one finds Embedding apps in vb6
Hello, can someone give me some help on how to embedd a window into vb. im playing with the destinator sdk and im trying to get it to embedd into my project.
thanks, Tom
hmm, seems i dont use the right words to search with
Test this in VB6. Need to have Destinator 2 SDK installed!
That's not embedded, I can move Destinator aroundOriginally Posted by Jeep
Yes in a way, you can move Destinator inside the picturebox. You have do edit Destinator inf file and set Destinators window to the same size as the picturebox. Inf file is here: C:\PowerLOC\Destinator\Common\Interface\Destinator .Inf Look for "D" ("D,650,412,640") (with,height,osk keyboard with)
Yeah, sorry. I meant you can still see the title bar and move it. you could also get the titlebar height in VB and move Destinator to picture1.top - titlebar height, same for borders etcOriginally Posted by Jeep
This is some code for embedding Destinator into a Visual Basic 6 (VB6) application.
(Sorry, just trying to put as many key-words into that first sentence as possible for anyone searching later!!)
Here is code to embed Destinator 2 into VB :
Make two timers, don't enable either. Give them whatever interval you want.
Make a Picture Box called pctDest (or change the code below) on your form and place it where you want.
Then put this code in your project.
Little bit of help with that code was from coyoteCode:Public Sub Form_Load() tmrLoadDest.Enabled = True End Sub Private Sub tmrLoadDest_Timer() Set Dest2 = New Dest Dest2.CreateDestinatorWindow 4 Tmr_LaunchTimeOut.Enabled = False Tmr_LaunchTimeOut.Enabled = True myhandle = 0 While myhandle = 0 And Tmr_LaunchTimeOut.Enabled = True myhandle = FindWindowByName("*Destinator*") DoEvents Wend Tmr_LaunchTimeOut.Enabled = False If myhandle = 0 Then Exit Sub CurrentStyle = GetWindowLong(myhandle, GWL_STYLE) CurrentStyle = CurrentStyle And Not WS_DLGFRAME CurrentStyle = CurrentStyle And Not WS_SYSMENU CurrentStyle = CurrentStyle And Not WS_THICKFRAME CurrentStyle = CurrentStyle And Not WS_MINIMIZEBOX CurrentStyle = CurrentStyle And Not WS_MAXIMIZEBOX SetWindowLong myhandle, GWL_STYLE, CurrentStyle SetParent myhandle, pctDest.hWnd ShowWindow myhandle, SW_MAXIMIZE tmrLoadDest.Enabled = False End Sub
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
hmm, i cant seem to get the code to work
I've tried it aswell. But it gives an error in the line "Set Dest2 = New Dest". Could anyone please explain what this line, is soposed to do.
