I have a few problems....
1. I have the X 10 Mouse Remote, software end on XP Professional I am running Winamp 2.8 or 9 stable (I think). I have trashed the software X10 gave me with the remote the first day i got it and DL http://max10.sourceforge.net (Awesome software, shame he doesnt update it). My problem is i am unable to update winamp to version 5 because max10 doesnt allow me to reprogram the remotes keys to work with 5 they have only worked in 2.x. Has anyone gotten it to work?
2. I had just purchased a Creative MP3+ (Fixed all of my audio noise) I installed it updated the drivers to remove pop noise etc. To shutdown my pc I will suspend it because its faster than shutting it down. when i start it back up I have no soundcard, in device manager i have a code 10 "device cannot start" when I try to play anything with winamp it will give me an error Title: Winamp 2 wave-out plugin 1.03
"A device ID has been used that is out of range for your system"
for more information go to http://www.geocities.com/mmsystem002/
To fix this the easiest way I found which is not easy with a MouseRemote is to End Task Winamp go into Device Manager uninstall Creative Sound Blaster then Scan for hardware changes and it works again. that sux and it only happened after I installed the Creative. It worked fine with the onboard sound. If I install winamp 5 I could possibly fix it but I wont be able to use my Remote which defeats the whole purpose.... Help![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
^^^^^^^^Good *hit^^^^^^^^
Any ideas on the upgrade to winamp 5 for the mouse remote?
Originally Posted by Axis_Inc636
Do any of the commands work ? Because I just looked at the source and as far as I can tell it's looking for the proper window, which is the same for Winamp 1,2, & 5
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
I tried to assign them a while ago, i read somewhere there might be something with the media playlist organizer in 5 that is stopping other x10 remotes from working with it. I will try again when I get done work to see what happens, I also have a pir8ted version of XP but previously had to hack it for service pack 1 so ill try to put in the Service Pack 2 beta to fix #2.
Well the service pack fixed mu USB problem but I still am unable to use winamp 5 with my remote, not even my mapped power (exit, close, shutdown ) button will close winamp 5, seems too strange, is there a setting to allow for winamp 2 compatibility im stuck on this one? has anyone else gotten it to work with thier mouse remote
My Webserver is fixed the pics are up
MP3 Blazin Blazer
14" MAG Desktop LCD in your grill
Over 5000 console gamez
Plus More.......
