Results 1 to 10 of 10
Thread: HELP: DivX with AC3 cant hear sound :(
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I am trying to get the DivX functionality working in the carputer.
    I have a DivX movie that is encoded with AC3. I have the DivX Codec Installed on my machine. I also have the AC3 codec installed on my machine. When I try to play the movie within MediaCar i get video with no audio. This to me would indicate a lack of correct codec. However I know the two needed codecs are installed.
    When I try to play it in WMP9 it looks for the codec and returns nothing (not connected to internet yet) This would even more indicate a missing codec. I guess my questoin is how do install the codecs correctly to work in Winamp or any player at that.
    I did some searches on other Divx Forums and yeilded nothing and i am hoping for a simple answer.
    Variable Bitrate NoPistonPC's Avatar
    Boston
    Run GSpot and load your DivX file. It will tell you:
    1) Which codecs your file needs
    2) Which (if any) of those codecs you have installed
    I'm assuming you already have the AC3Filter codec installed, but if not, go to this page. Download it from there and then go down to the bottom of the page where it says "Step 3". Read that for information on how to configure it properly.
    Jan 2004
    California
    So I downloaded and installed Gspot and it says that I have the propper AC3 filter loaded (as i supected) and the propper DivX codec installed aswel. however i still cant get any audio out of this divx movie.
    What gives.
    It would appear that I don't have the correct codec installed by the behavior of the media players but i have to assume I do because Gspot tells me so.
    Also I tried getting audio through both analog and digital. No love
    Any help .....please
    Boston
    Hmmm... that's really strange. So GSpot can find the AC3Filter codec, but WMP can't???
    Try uninstalling all your old codecs first (through add/remove programs) if you have any. Then reinstall AC3Filter.
    If that doesn't work, try VideoLAN. It has a bunch of its own built-in filters and doesn't rely on external codecs. I know that won't fix your MediaCar problem, but it will help with trouble shooting. If it doesn't work in VideoLAN either, there might be a problem with the AVI file.
    Do you have this problem with ALL of your DivX-AC3 movies?
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    I had a similar problem with normal stereo Divx files... No sound....
    Well... I found out I had Divx 5.1 and they have a new release 5.1.1 .....
    After I installed the new rev... it fixed the sound in those 2 Divx files I had downloaded.
    Just a thought....
    Jan 2004
    California
    At the present I only have 1 divX movie (actually 2 but it is really 1 movie split in half)
    The movie is fine becasue I can play it on my laptop fine. But WMP and Winamp cant play the audio.
    I will check to see what version of Divx codec I have and then try uninstalling and reinstaling the codecs. I will keep you posted. I am going to do this tomrrow at luch and will post the results
    Mar 2004
    You don't have the proper AC3 Codec.
    Go here: http://home.hccnet.nl/h.edskes/mirror.htm
    Download and install the K-Lite Mega Codec Pack
    It will include everything you need for every video file out there.
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
    Jan 2004
    California
    Quote Originally Posted by ryguy
    After installing rebooting and configuring i know have sound.....wooohooo Matrix Reloaded . Know I have to download the rest of the triligy.
    That mega codec pack is awesome. 18megs but know i should be able to play anything
    Thanks a bunch
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by antimatter
    Thanks a bunch
    I assume by "download" you mean from the DVD you own to you computer ?
    Just a FYI you can easily join those two halfs into one using the free program VirtualDUB.
    Tutorial link: http://www.divx-digest.com/articles/joinavi.html
    Mar 2004
    Your welcome Its the best codec pack out there
    7" Lilliput LCD
  1. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  2. Wanted: Clean sound from carpc
    By slushieken in forum Car Audio
    Last Post: 06-20-2004, 10:17 AM
  3. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  4. hissing sound
    By maxima13 in forum General Hardware Discussion
    Last Post: 04-30-2002, 11:28 PM
  5. Need advice on which sound card to use
    By mtmsol in forum General Hardware Discussion
    Last Post: 06-22-2001, 01:39 PM
