How do I apply ?
Add me, frodo9fingers
The project is now available at:
http://sourceforge.net/projects/cajun-4-win/
Does anyone know a good patch management system for Windows? I know most people don't have access to use 'patch' for Linux...
For the moment, if you do have access to 'patch' for Linux, you can submit the patches via SF's site. I'll add them in ASAP.
If there are any people who wish to be developers, then you can apply and I'll approve you ASAP.
How do I apply ?
[H]4 Life
I'm a lesbian too.
I am for hire!
You should have access now...Originally Posted by frodobaggins
CRC
What, other than VB do I need to install.
I tried to modify it, but get compile errors on
FrmMain.Player.settings.volume
Method or data member not found.
Do I need the MPlayer SDK installed? If so, do you have a URL for this?
PS
Whats wrong with cygwin+diff+patch?
.//Daren
(Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
MediaCar/CoPilot7/Routis
One other thing CRC [ I prefer MD5's],
Why did you pick wmp? There is a winamp COM object that would be just as suitable and it doesn't come with the WMP baggage?
Its your project, so your call, I was just curious.
In true Linux open source tradition I should branch the project and redo it to use Winamp
I found a media platform SDK on my MSDN disc's so im trying that...
.//Daren
Turns out I need WMP installed to use it! Well, who would have thought that.
I had to create a VirtualPC to use for this, since I dont want WMP from having its way with my dev system. You might not want to use WMP if you knew all that it does...
.//Daren
Ive been hacking around with it and my impressions are:
- the song progress indicator needs to go, replaced with something less scrollbar'ish.
- The selection of tracks is fine with a mouse, but not a touchscreen.
- the top section, the folder selection needs to be redone
- the lower section, song selection needs to be redone, id3 tags, not file name, no scroll bar, but buttons linked to the control
- change settings.dat to an ini file
- support in settings.ini the ability to select colors for fore/background of controls/text, its on thing changing the back image, but the text/control colors need to be controllable otherwise you might not be able to read them.
- The playing song details could do with some sprucing up a little, I dont know yet, im playing with using some LED-like font, might look like crap, but I'll see.
- Need random play.
- Needs playlist support. It might already have this, I dont know much about WMP, so I may have missed it.
- I like the left margin thing, but its realestate that could be used for something more productive
.//Daren
Gave you some ini stuff.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
I wholeheartedly agree with the features that mobileh1 suggested, especially the ID3 tags and playlist support. Cosmetics and aesthetics you can worry less about, since it's now open source, but for a final release it would be a good idea.
I was actually working on trying to develop my own player last night, and I came accross this site with code to retrieve ID3 tags:
http://www.devx.com/vb2themax/Tip/19277
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
Thats cool Wizard, since I haven't used VB for years. Looks about the same though. Its seems perfect for this kind of application.
I will add the mp3 support.
.//Daren
