Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: RDS and TMC
  1. #21
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    @BeamrRider: Did you ever get this library coded/debugged? I was checking google to see what was out there and only came across a partially implemented libarary in sourceforge. Unfortunately, it doesn't yet implement error correction so it isn't going to be too useful. The essenginer freeware application should be immensely helpful for debuggging.
    I need this code for Seth's radio project. The tuner ICs to be used will output the demodulated RBDS/RDS bit-stream and clock. These are TTL level signals and are directly comppatible with most modern RS232 recievers without level conversion. Worst case I'll toss in a max232 family IC for level conversion.
    I'm happy to toss a simple GUI front end on whatever you've got. Thanks for any help....sorry for reviving an old (and hopefully not dead) thread.
  2. #22
    Maximum Bitrate PTCruiser's Avatar
    Oct 2002
    Switzerland
    @BeamRider a member of carmedia has a usb radio with RDS decode in developpement...
    Could it be possible that you share the source code of your software decoder library?
    Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
  3. #23
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by BeamRider
    looking on the web I noticed that many PC FM tuners (both USB and PCI) are not RDS enabled so, after some search I started building a very small and inexpensive demodulator and level converter for the serial port and a software decoder library in C++. This version of the library is not very clean nor readable but it's working. Major features are:
    - Basic RDS decoding: AF, TP, TA, PTY, ecc (AF can't use grouping by now)
    - Pluggable interface "streams" (COM and Logfile implemented)
    - Pluggable ODA classes
    - TMC decoder(ODA plugin): not completed, but able to decode single mesages, locations and events and much more ...
    I've built two simple MFC application (console and windowed/MDI) to test my library and I'd like to hack a D-Link radio instead of the Clarion HU that I'm using now.
    My wish is to obtain an RDS capable tuner GUI (guys, I don't like GUI programming) and to be able to have TMC messages in Destinator via its SDK but I'm not sure if it'll be possible, maybe with V3.....
    Someone wants to add RDS/TMC in its project?
    Beamrider.... a post from the past but is there any chance I can get a copy of your app / info ? I have a TMC receiver now and would like to make use of it.
    Cheers
    Terran
  4. #24
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by ccsnet
    Is that a traffic master with expired subscription?
    Some time ago hex was floating about to re-program it with that made th sub 99 years.......
    almost makes me want to go to the scrappers to rip 1 out of an old xantia/vectra/astra
    But, as the unit receives all the info just does not act on it, its already receieved it so tapping that data off to a software decoder is viable.
    keep meaning to build an interface for my old (battery portable) one and then go sit under a tower at rush hour to see how the data changes with trafiic movement etc.
  5. #25
    Jan 2003
    Quote Originally Posted by lez
    No its not I am affraid... but I know exactly what your talking about
    Terran
    BTW - The signal is sent over the old 400mhz paging channels....
  6. #26
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Ok so thats got me a bt confused......(really easy to achive is that)
    1) which one is sent over 400mhz
    2) if its not the hardware I was thinking of, what hardware is it?
    3) why is it not a taxi..........
  7. #27
    Jan 2003
    1) The Traffic Master data - all of it..... via the Vodafone paging system if I rember using a version of POSAG
    2) http://www.cartft.com/catalog/il/392
    3) See the CNet review.... still not happy about that... link off my home page
    Terran
  8. #28
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    god i want one of these.....
    anybody have this one http://www.expansys.com/product.asp?...rtner=register ?
    I cant believe there isnt a ton of software out for this stuff yet.
    PC Components:
    My work log
  9. #29
    Dec 2004
    Maryland
    this looks promising http://www.alturion.com/support/file...MConlaptop.pdf
    too bad they dont sell in the states, also I can't find any info on their "usb" gps tmc receiver
    PC Components:
    My work log
  10. #30
    Newbie Montanaja's Avatar
    Jul 2005
    Ypsilanti, MI
