Results 11 to 20 of 27
Thread: New Project: Contrast Mediaplayer
  1. #11
    Jun 2003
    Kansas City, MO
    Just want to give you all an update on the status of this project.
    Today I finished the core framework and began work on the actual interface by modifying the model format I've written to auto generate bounding boxes to use with object picking that will go in tomorrow. Once the object picking is complete the project will take another week before a simple media player demo is made availible.
    So far the system supports any sound file that FMOD offers. A complete list is availible at: http://fmod.org/fmodfeatures.html#sece.
    Since it uses a custom model format this requires the use of a special exporter for Milkshape 3d if you wish to model new buttons or objects for the interface. The skin system will then be used to specify what models belong to what interface object. And since the entire system will use a module api for expansion, the skinning system will also support the loading of custom designed interfaces for your module.
    So for instance if you created a new playlist manager, you could use the skinning system to either integrate this with the media player or design your own interface. Its quite expansive actually.
    Hopefully the interface is as simple to use as I hope it will be because I'd love to see this running in other peoples cars someday.
    But enough rambling for now, I must sleep now for I have work in 6 hours.
    Philip Plante
    my projects:
    idgn.org | idgnonline.net | contrastsolutions.net
  2. #12
    Jun 2004
    You sure plug your webhosting site enough
    Let's see some screen shots.
  3. #13
    Jun 2004
    So... Three days now, any updates/screenshots?? I'm anxious to see this!
  4. #14
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by pplante
    The interface would feature 3d objects with which the user would interact with
    Although, I'm sure it will look real cool, you do not want to have any objects that the user has to interact with. If you really wanted to make a non-distracting interface you would find a way to have user's perform complex actions without them looking at the screen. i.e. instead of having a 3d ball covered with song names that you have to rotate until the song you want to play is visible you would simply have a horizontal motion made on the screen correspond to changing to another song and depending on the magnitude of the motion, you select a different song. This inturn coudl rotate the ball to the selected song, but would not effect which song was selected and therefore not require the user to look at the screen to use it.
    I don't see how making a 3D interface could be anymore usable especially when when using a 2D input device (touch screen) to control it. One reason why 3D interfaces are sometimes thought to be better is because they offer a perspective that is closer to real life which user's have the most experience manipulating things in. However, by doing a 3D interface controlled by a 2D input space, you simply force the user's to learn not only how to use the 2D input device, but additionally how to use this input device in a 3D space which may not be a hard thing for you to grasp, but most certainly will not be a natural thing for most users.
    The other reason for using 3D interfaces is to be able to display more information in a smaller space and give user's a visual que of how to access a particular function with less used functions in the background. This may work on a desktop where the number of functions that need to be performed are numerous and the primary task requires looking directly at the screen. However, in a car, where the visual resources are taken up by other critical functions, like driving, it certainly is not a good idea to add yet another visual axis to put things in that would require the user to study the screen for periods of time to find the proper interface. Rather the better way, in this case, is to require a more expert interface that requires the user to learn the layout and location of functions to use them and offer large touchable areas to navigate to them.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  5. #15
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    I for one think this is a great idea, i live, breath and eat polygons
    A 3D interface wont be any more dificult to interact with than a 2d interface and there really arent any features that make either one better to use than the other. 3D is just cooler looking. 3D has the possiblitly to be extremely harder for someone to use if done the wrong way, but so can 2D stuff. My only advice would be to not give the end user (not skin makers) control over the camera or direct object interaction other than selecting and everything should be cool.
    What engine are you using, is this custom, if so what does it support and is milkdrop the only option for your exporter, would you consider making the exporter work with XSI or 3DSMax ? Or maybe another free or lowcost basic 3d package since not everyone would be able to get xsi or max to do skins.
    Do you have a site up for this project yet?
  6. #16
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Does this mean you'll be using my 'Contrast' skin ?
    T
  7. #17
    Jun 2003
    Kansas City, MO
    What contrast skin?
    And probably not considering its all 3d models
    Philip Plante
    my projects:
  8. #18
    Jan 2003
  9. #19
    Maximum Bitrate mobileh1's Avatar
    San Francisco
    Computers, on the whole, use 2D interfaces and I can work them just fine; women on the other hand are typically 3D and their interfaces are nearly impossible to figure out, for example, I have tried to get my wife to go into stand-by mode for the longest time.
    .//Daren
    (Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
    MediaCar/CoPilot7/Routis
  10. #20
    Jun 2003
    Kansas City, MO
    did you forget to replace the batteries in her remote?
    Philip Plante
    my projects:
  1. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  2. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  3. Hello!! CarPC project pics inside.
    By bobbykokinos in forum Newbie
    Last Post: 03-29-2004, 12:44 PM
  4. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
  5. My older project looking for USER INPUT!!! Please
    By SoloCon in forum Show off your project
    Last Post: 10-22-2003, 03:27 AM
