This might be a stupid question, but would this work for CoPilot 7 too?
Here is LMF 1.1, Now for MediaCar and MediaEngine.
(It's a launch helper for those stubborn apps)
Code:© 2004 Kevin Lincecum frodo |at| frodoplayer.com Launch ************ ! v. 1.1.0 Usage: Make a seperate directory for each app you want to launch. (Seperate LMF instances, ie. a whole new directory with all the files in this release.) Edit the LMF.INI file with the path to the program you want to launch. [MAIN] COMMANDLINE=C:\Program Files\XM Satellite Radio\XMMT.exe COMMANDLINEOPTIONS=127.0.0.1 /q /s /r2d2 UNLOAD=FALSE You should set UNLOAD=TRUE for MediaCar and set UNLOAD=FALSE for MediaEngine. --------------------------------------------------------- For MediaCar Make a folder in the launch folder. Example: XM Make an XM.JPG in that folder. Make and XM.INI in the folder. In your XM.INI point it to an instance of LMF.EXE Example [GENERAL] PATH = C:\Program Files\MediaCar\LAUNCH\XM\LMF.EXE TryEmbeddedTimeOut = 5 WindowSearchString= --------------------------------------------------------- For MediaEngine: Add LMF.EXE to your applications section in MediaEngine. Notes: Closing this app will NOT close the app you launch. You must close the called app manually. --------------------------------------------------------- Have Fun, Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
2002 Subaru Impreza WRX hatchback - Silver.
IBM Thinkpad T21 800MHz 256Mb RAM 20Gb HD
Lilliput 7", CoPilot, MediaCar
Pyramid Super Blue PB442X 300w 4ch Amp
Creative SB MP3+ USB
Why don´t you try?Originally Posted by peegee
