Results 1 to 7 of 7
Thread: Are there any software EQ solutions?
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I'm planning to run my EPIA directly into a power amp. Are there any software solutions in existance (besides WinAMP) that will provide a graphic or parametric EQ? It would be really cool if this was built in to one of the car media players.
    Sep 2003
    Wilkes Barre, Pa
    None that I know of unless you write your own. My software uses the fmod with a 10band graphic EQ built into it. You can also use bass.dll.
    Sep 2003
    Elgin, IL
    not as simple as the EQ in winamp but you might want to look at dee2/dee3
    Jun 2004
    Toronto, Canada
    I just found an EQ for my EPIA board. I found the latest audio drivers for it, installed them, and there was my EQ.
    I'm not sure if it was there before installing the new drivers, but all that matter is that I have it now. If your mobo has the matching chipset, you can find the VIA Stylus drivers here:
    http://www.viaarena.com/?PageID=69
    -> Launch the "VINYL DECK" from START->Programs->Vinyl Deck. Once it loads, click on the Sound Effects tab.
    I still wish this functionality was built in to the car media players, but it's better than nothing.
    Maximum Bitrate mobileh1's Avatar
    San Francisco
    Before you all rush off and try this here's a word of caution.
    I did just that, and I run winamp, plays muffled and awful. If I bring up the vinyl deck app and adjust one of the eq sliders even the slightest bit its bright and sounds perfect again. Then I restart mediacar/winamp etc and its back to muffled.
    Ill play with it some, but the M10,000 and these drivers seems to have some problems...
    .//Daren
    (Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
    MediaCar/CoPilot7/Routis
    Jun 2004
    Toronto, Canada
    I've got it installed on my MII-10000. It seemed ok with WMP. I'm still setting up and configuring the system (brand new), so I'll see what happens once I get other software installed.
    Mar 2004
    I found this, might help but havent tested it yet...
    There is demo available....
    http://www.audioenhancedps.co.uk/rad...oundRouter.htm
    It allows to route audio through directx plugins and there is many professional EQ:s available so i think this is best solution yet (if it works that way)
    Try that.
  1. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  2. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
  3. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
  4. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 11:17 PM
  5. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
