Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Where and whay is needed to start..
  1. #21
    Low Bitrate cyber's Avatar
    Jun 2004
    Frozen Tundra
    VB6 is a good language to start in because the syntax is easy and building GUIs is brain-less. If you want to build a robust modular application then C++ is the way to go. I know you can get semi modular applications with VB but its still not true OO nor is .net. It all boils down to what your trying to get out of your learning experience: Good OO design and implementation (C++) or something thats quick and easy (VB6)
  2. #22
    Jun 2004
    Frozen Tundra
    Quote Originally Posted by frodobaggins
    Because I do not know VB.net, among other reasons.
    Frodo
    other reasons = .net is a bastardization of vb and java
  3. #23
    Constant Bitrate Adam432823's Avatar
    Nov 2003
    S.F. Bay Area
    Quote Originally Posted by Exo
    Learning by doing is the only way!
    I'd say that that is true up to a point. If you never take a class or read any books, its likely you're going to end up writing sub routines for built in functions or making huge chunks of code that someone else has already figured out how to make smaller. Learn the basics on your own, but going to a junior college and taking a class or picking up a book is still a good idea.
    Also, I'd recomend staying away from .NET at first. That's my opinion and you may disagree, but I picked up VB.NET after learning and using VB6 and its pretty f*&^ed up in comparison.
