Results 1 to 10 of 15
Thread: Picture Viewer (for developers)
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Red face Picture Viewer (for developers)
    Hi folks,
    got a picture viewer for you.
    It's nothing special ... basically the same frodo did... except it's completely .NET
    This means, that you have to install the .NET 1.1 runtime (which you already have, if your a PhoCo user).
    For all those of you who are looking for some samples how to write .NET applications I've releasing the source code as well. I've put as many comments into the source, so it should be easy to step trough.
    To configure it, take a look into PicViewer.NET.Config.xml... i think it's mostly self explaining.
    PicViewer.NET
    BTW: I'm not gonna support it... you have the source code... do it yourself
    Skinning to go... VisualDesigner2!
    Jul 2004
    I'm getting a error message each time I try to start it...
    "Application has generated an exception that could not be handled.
    Process id=0x610 (1552), Thread id=0x598 (1432)"
    Mar 2004
    Munich, Germany
    Lightbulb
    Quote Originally Posted by tCoy
    Install PhoneControl first and try it again
    Usually, there has to be a setup to apply the access rights...
    <edit>
    Forgot to mention this:
    Copy the Microsoft.DirectX.*.dll from the PhoneControl directory to the PicViewer directory... then it's supposed to work
    </edit>
    Jul 2004
    Quote Originally Posted by zorro
    Already had PhoneControl installed.....but this worked.
    Mar 2004
    Munich, Germany
    I beefed it up a bit...
    • If you now plug in a new media (let's say a memory stick, MMC/SD Card), the app will recognize it and start a slide show automatically, in case the device has some pics on it.
    • A path to pictures now can be applied as a command line parameter... with that you may configure various directories.
    • Each given path will be browsed and if it contains subdirectories with pictures, you'll get a listbox to select one of them.
    And... I've put the missing DLLs into the ZIP file
    Jul 2004
    werd
    Mar 2004
    Munich, Germany
    werd
    I totally agree... whatever this is supposed to mean
    Newbie AndyXR's Avatar
    Feb 2005
    Slovenia
    It is a great little APP but why is it sooo slow? I mean the buttons.. Could you change that so they just dissapear instead of slide out?
    Epia M-800
    160GB HDD
    256MB RAM
    Slim DVD
    Morex Case, M1-ATX
    GPS Mouse
    Bluetooth
    WiFi
    OBD II
    Liliput 7" Touch
    Jan 2003
    Ruston, LA
    Way to revive an 8 month old thread there.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    Did you notice this in the first post?
  1. Replies: 55
    Last Post: 12-03-2006, 08:57 PM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  3. 200 Watt DC-DC PSU
    By Deadnick in forum Power Supplies
    Last Post: 05-22-2004, 04:08 PM
  4. Feature Request: Picture Viewer
    By aphesis in forum MediaCar
    Last Post: 11-27-2003, 11:09 AM
  5. LCD picture quality not good. Will shielding help?
    By pigseye in forum General Hardware Discussion
    Last Post: 12-27-2001, 10:51 AM
