*cough*
CarPC install is starting to come along again...
*cough*
Well if you aren't using WMP for your MP3 playback then adding it for your DVD/DiVX will just blot the hell out of your app.Originally Posted by Grayscale
What are you using for MP3 playback?
Winamp
If you like working with COM then wmp is definitly the way to go. If your doing it in VB the wmp control is probably the easiest way to go. If you want the most control over the application and want to do things like draw complex stuff on the moving video then your probably better off just using the DirectShow portion of DirectX, although doing it this way in anything other then C++ would be more of a challenge then I would want to undertake.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
Not working with COM...I'll probably check out the wmp control for VB. What about suggestions for DVD? WMP doesn't do DVD right?
WMP does do DVD but you need to have another DVD codec installed first.
How about VLC? Its a feebe and it supports just about everything under the sun.
System Status - Starting Over
Computer: None
Vehicle: Silver 2002 Malibu
DirectShow is the best way to go. You won't get the bloat of an external app like WMP or Winamp and it will automatically use the DVD playback filters of a DVD app like WinDVD or PowerDVD.
You should be able to use it from VB. I'll post some sample code for you in a minute.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
I looked into this, but I couldn't find good documentation for the development library. Let me know if you know of anything.Originally Posted by xanimal
