yeah, the integrating part works great![]()
vcbb5, i haven't implemented the fullscreen code yet, but it can be done. Currently, the windowed mode will only work if you ckeck "integrate with winamp". I have a bad habit of leaving things unfinished (mostly due to the lack of free time). But, I promise to finish this up since it's not going to be too hard. At the least, I will make sure it works with FrodoPlayer. (it will have to wait until after this weekend though)
EDIT: I just tried it out with FrodoPlayer, and it actually works fine (in non-fullscreen mode). My config file looks like this (but I don't think there is anything in there of any relevance...try deleting your current milkdrop config file...it will generate a new one):
(milkdrop_config.ini)
[settings]
nMainWndTop=60
nMainWndLeft=32
nMainWndRight=272
nMainWndBottom=204
avs_wx=0
avs_wy=0
avs_ww=240
avs_wh=144
What I did was to make sure that "integrate with with winamp" was checked in the config screen (I changed the config through winamp, then uninstalled winamp...this doesn't affect milkdrop which probably uses the registry). Then I ran WMP and selected the MilkDrop Vis. Then, I quit WMP and ran FrodoPlayer, and it ran MilkDrop in the vis window without any problems. When I have some time, I will try to make this process a lot simpler.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
NoPistonPC,
This is absolutely not a "put down" on your awesome work, but I have been using TwistedPixel with WMP/FrodoPlayer for about 2 months now, using MilkDrop visualisations.
Just another approach
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Any updates on this? I would really like to use all of the Visualizations of Winamp in WMP
I'll get to this soon, I promise.Originally Posted by antimatter
Do you have a list of your favorite viz's? I'll get those working first.
Sweeet!
Geiss, Please
Trust me, I know what I'm doing!
what ever happend to this project?
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
sorry for leaving this half finished guys... for those of you that don't feel like waiting until i get my act together, i can send you the VC++ source.
The good news is that I finally finished molding my screen into the dash a few weeks ago, so I still have motivation to finish this up (as well my HeadUnit linux frontend)...
Would it be possible to make them into a directshow filter? Someone else on this forum said they would have a go, but i don't believe anything ever happened.Originally Posted by NoPistonPC
We are, will have and forever will be...
But not tommorrow!
Well i found the post. It turns out it was you NoPistonPC who said he was going to have a go at it.
what video backend to use?
But not tommorrow!
