Page 6 of 6 FirstFirst 123456
Results 51 to 53 of 53
Thread: WinAmp visualizations in Windows Media Player (almost working)
  1. #51
    Apr 2007
    SenseiTG you are my hero!
    I've always wanted to get MD working in WMP but the hacks always seemed to crash WMP. This compile is totally stable and looks great!
  2. #52
    Aug 2007
    Vista 64 bit
    I'm running Vista Ultimate 64 bit edition, and I cant register the library. The error I get when i run the command line is:
    The Module "C:\Program Files\...wmpmilkplug.dll" failed to load.
    Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files
    The specified module could not be found.
    The weird bit is that dot on the bottom of the message. Asif its looking for an unspecified library - or maybe im just looking too hard. Meh I dont know - I didn't write it. But I would love to get AVS working in Media Center. Let me know if you have any ideas
  3. #53
    Apr 2007
    Quote Originally Posted by spankey666 View Post
    First off, I need to tell you that the plugin has now been tested with windows vista and it does not seem to work. I am running vista myself and can't use the plugin but I have some more interesting audio/video visualization projects (http://tgtech.blogspot.com/) going on at the moment, so currently I have no plans to create a vista compatible version.
    However if you do want to try it anyways (maybe it'll work on your machine, who knows, but I doubt it) there is an additional issue to the installation. When logged in as a normal user you are not allowed to register dlls for safety reasons. Might be a problem even if your user is configured as administrator. What you should do is switch user to Administrator and register the dll from there.
    Also, if anyone is interested in giving a go at making the plugin vista compatible, source code is available upon request.
    Also, since I've never used Vista 64 I can't be sure if a 32bit dll will work at all. But I think it should.
    Regards, D
  1. windows xp media center edition
    By the_spy_guy in forum XP MCE
    Last Post: 04-15-2006, 02:26 PM
  2. 4:3 aspect ratio with windows media player
    By Mikesz in forum Software & Software Development
    Last Post: 02-24-2006, 03:10 AM
  3. working g35 winamp skin
    By liquid_smoke in forum Software & Software Development
    Last Post: 01-20-2004, 11:33 PM
  4. How To: Power, Startup, Shutdown, Windows Media 7, BookPC
    By DAlba in forum General Hardware Discussion
    Last Post: 05-05-2000, 09:50 PM
  5. Windows Media Player 7 Beta
    By DAlba in forum Software & Software Development
    Last Post: 05-05-2000, 07:35 PM
