Results 1 to 5 of 5
Thread: Bios Flashing Problems
    trdcpu's Avatar
    Feb 2004
    Colorado
    whenever i try and flash the bios of one of my kiosks, i have serious problems.
    i made a boot disk, boot to dos, then put in another disk with the bios update. then i proceed to type in A: prompt, "phlash kioskst4.rom" which follows the precise directions, anyways, the flash program opens in dos, and gives me an error that says "cannot continue with bios update while memory managers are present, e.g HIMEM." how do i remove these memory managers, and get this bios update working? thanks for the help
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    edit your config.sys and/or autoexec.bat file
    remove the line for the memory manager
    going back years when dos ruled I think you can pretty much "rem" each entry in both these files, the system should boot to the command prompt then
    good luck
    everyone thats into pcs now missed the great learning curve of dos ! who remembers those days and the days of 4 colour screens being hip and hot and 640k of memory was like WOW
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    FS = MTSVO motorised in dash screen pm me for details
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    You could create a startup floppy within XP (you will find an option if you try to format a floppy). The startup disk XP creates is pretty basic and does not include any memory manager (I think )
    Jun 2004
    Upstate New York
    First monitor I owned was an amber monochrome (I did have 640k though) I remember spending hours playing Castle Wolfenstein on that monitor, glad it was a monochrome game. Hmmm matter of fact I think I have a ROM of that for an Apple IIe emulator around here somewhere.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Apple IIe was the ****, that was my first comp. Awesome dual 5.25" floppy drives. Spent hours playing Oregon Trail. I still play Oregon Trail every once in a while with the Apple IIe emulator.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  1. Strange M10000 problems
    By cyber in forum General Hardware Discussion
    Last Post: 03-04-2005, 02:10 PM
  2. problems flashing Epia-M1000 bios
    By Birrman54 in forum General Hardware Discussion
    Last Post: 09-19-2004, 08:54 AM
  3. BIOS wont stay saved?! Turn on carputer...always the default bios setup...HELP!?!
    By Cadillac_LoungN in forum General Hardware Discussion
    Last Post: 07-17-2003, 03:26 PM
  4. Harddrive problems....bios?? or just OE
    By stinkynathan in forum General Hardware Discussion
    Last Post: 11-18-2002, 11:15 AM
  5. Ati mobility bios modifications?
    By Odie in forum LCD/Display
    Last Post: 09-28-2002, 03:26 PM
