Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Changing Windows XP color scheme at night
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    I was wondering if anyone had found a utility that can change the color scheme in windows at a certain time (or could be run from a script that executes at a certain time)? I would like to have dialog boxes and whatnot switch to better colors at night.
    Having support for skin-switching at a certain time in the various frontends is great, but there's no way to do it on a more generic level..
    I have seen the gamma adjustment app.. nice; but all I want to change is the color schemes.
    Thanks!
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    hmm, this is an interesting thought. I am not aware of any applications that do this, or how windows does it, but I am sure it can be done. One way to do it would be to have two user accounts and make a program that switches between them depending on the time. I will look into how easy it is to switch themes and reply here. Are you using any specific themes? like that wincustomize or just using the normal windows themes?
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Aug 2003
    Amarillo, TX
    Yes; just standard windows themes to keep it fast.. Actually, I'm just using the 'standard' windows look not even the rounded corners, though I know that it does still use the XP style engine...
    MY CAR IS FOR SALE!
    Nov 2003
    NC
    So you want to switch from what to what??
    I am at work right now and they have group policies on the xp machines, so I might or Might not be able to try out some source code.
    Cross your fingers :0D
    Aug 2003
    Amarillo, TX
    I just want to switch the colors.. ie the stuff in Display Properties -> Appearance -> Advanced.. like the dialog box colors, scrollbar colors, default background color, text color, menu color, etc..
    Black text; white BG is great for daytime but at night something like white text grey bg would be better..
    MY CAR IS FOR SALE!
    Nov 2003
    NC
    Ahh I see, what you want to do is quite difficult with just the registry. Have you made two themes up that you want to use?? I will make two on my home computer and try to switch between them using an app I can try to write. Im sure it can be done, just not sure if my knowledge can do it
    Aug 2003
    Amarillo, TX
    Sure; themes contain the color info too, so this would work fine. Thanks for looking into it.
    MY CAR IS FOR SALE!
    Nov 2003
    NC
    Found some code that demontrates how to do this with the default windows themes, I will try to figure it out using custom themes. Once its figured out the rest is quite easy. Will work on it when I get home, and post any source code / instructions / findings here for some one else to take a look at, will be doing it in VB6.
    I am unsure of this at the moment, but does any one know if windows 2000 themes are the same as XP themes? I have a Virtual machine of XP but would prefer to use a non-virutual machine.
    Elsewhere
    Quote Originally Posted by gork
    Thanks!
    Just thinking....
    If you setup two themes with the colors you want and then setup a scheduled event in Windows 'Scheduled Tasks' to have XP load a specific theme at a certain time....
    Another way to do it: Have a button on the quicklaunch bar, or on the desktop where you have easy access to it so you can switch wenever necessary.
    How about the Wiki?
    Aug 2003
    Amarillo, TX
    Problem with scheduled events is that they only run at certain times, so if you boot your car pc say at 8pm and your night theme was supposed to have run at 7:30 you would have missed it..
    Is the theme changing built into scheduler? Not on an XP machine now so I can't check... If it is, maybe it's just kicking off a rundll call that we can use to write a script for the startup items...
    MY CAR IS FOR SALE!
  1. epia M 10000 AND WINDOWS XP PRO
    By Dluvr22 in forum Software & Software Development
    Last Post: 10-18-2005, 09:04 AM
  2. TUSI-M CMedia Windows XP sound problems.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 07-19-2005, 02:45 PM
  3. windows 2000, xp and EPIA 800
    By samc in forum General Hardware Discussion
    Last Post: 08-24-2003, 09:41 PM
  4. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
  5. Windows XP Suckage
    By vickumar in forum General MP3Car Discussion
    Last Post: 02-05-2002, 01:35 PM
