I have most of it working but, I want my skin installer to find the font Dir. and register the font. If you understand NSIS script I would be greatful for your help. Here's a link to the font reg plugin http://nsis.sourceforge.net/archive/...instances=0,11 , and here's what I need to know about.
What should $FONT_DIR be changed to? It only allows "a-z", "A-Z", "0-9", '_' (I think thats how it reads) The var needs to cover all windows versions.After including that file in your script you should make sure that the '$FONT_DIR' variable is set to the right fonts directory of the target machine. Also of note is the last command in the fonts Section, it enables Windows and other programs to refresh their fonts lists without the need to restart the computer. You MUST also include the FontName.nsh file from the FontName plugin.
