Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Mp3 To Mp4 and Mp4 to Mp3 ALL things MUSIC!
  1. #11
    Low Bitrate radioman193's Avatar
    May 2001
    Dansville NEW YORK
    Quote Originally Posted by god_of_cpu
    A 56 KBit MP3 will NEVER sound any better then a 56 KBit MP3 regardless of what you convert it to. It doesn't make any sense to convert a lower bit rate file to a higher bit rate one just for quality reasons. The way an MP4 will sound better then an MP3 is if you convert them both from the original lossless source.
    I doubt MP4 will catch on like MP3 given the prevelance of good license free encoders like OGG Vorbis and the even bigger fact that microsoft is pushing for its own WMA encoding to become the next standard.
    Its NOT a lower Bitrate its a totaly new type of compression than mp3
    MP4 96 = Around 160 Mp3
    MP4 196 = around 256 MP3
    256 Mp4 = around a 320 Mp3.
  2. #12
    Jan 2003
    Ruston, LA
    So what ? It still won't sound any better unless you reencode it from the original source.
    If you reencode it from the mp3 it will sound worse.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    May 2001
    Dansville NEW YORK
    Quote Originally Posted by frodobaggins
    No it dont Try it first
    tested here in the sound studio.
  4. #14
    Jan 2003
    Ruston, LA
    Quote Originally Posted by radioman193
    I don't have to try something that is impossible.
    You cannot improve something that was encoded in a lossy codec
    by encoding it into something else.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #15
    May 2001
    Dansville NEW YORK
    I NEVER! sed inprove in SQ. you can never have a better sound than the master but WILL sound the same.
    its in >SIZE<.
    with NO lossin SQ.
    MP4-audio sound (eg ACC audio). The cool thing I found too is that it Don't seem to use much more CPU-power than MP3.
    links if you want to see others info.
    http://www.xlr8yourmac.com/audio/mp4...dio_tests.html
    http://www.xciv.org/~meta/audio-shootout/
    with samples not for Cheep Pc speakers!
    http://www.xiph.org/ogg/vorbis/listen.html
    http://news.com.com/2100-1023-220233.html?legacy=cnet
    http://gear.ign.com/articles/442/442...html?fromint=1
    Im not trying to tell you all what you shuld do i just put the facts out here for you to see and hopefuly try them for your self .
    And thay sed that the Earth was flat.
    and that man cant fly.
    Then TRY and find alot of things out for your self.
  6. #16
    Jan 2003
    Ruston, LA
    It will not sound the same either. YOU may not be able to tell the difference, but
    a lot of people will.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    May 2001
    Dansville NEW YORK
    just give up
  8. #18
    Jan 2003
    Ruston, LA
    just give up
    Why would I give up when you are the one ranting about stuff you
    don't understand ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  9. #19
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    You're converting one lossy compression into another lossy compression.
    Each compression technique "throws out" different sections of the audio.
    Just so that you can understand this:
    WHEN TRANSCODING, FROM ONE LOSSY CODEC TO ANOTHER YOU WILL ALWAYS LOSE QUALITY.
    The only way you can convert to another compression format without losing quality is if you originally ripped it in uncompressed WAVE files, or in a lossLESS codec, such as FLAC.
    You ever been to have you hair cut?
    You start off with a full head of hair, then when you compress to MP3 you cut some off. You can't get that data back, and make your hair longer again. If you try to play with it (by converting your audio from one codec to another), you will only end up cutting more off.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  10. #20
    May 2001
    Dansville NEW YORK
    don't understand ?
    listen i understand alot more than you might think
    this post was to put info out so Others can find things out for them selvs
    True NOTHING SOUNDS AS GOOD AS THE MASTERS!
    The point is that if you have a **** load of mp3's you can convert them to the mp4 format @ the PROPER Bitrate for the file you are going to convert. and SAVE SPACE AND have the SAME sound Quality as the Mp3 you started with.
    and you can still play them on a car pc if it uses media player as its core.
    The Point You are Trying to Rip out of this Is
    MORE Songs In your Car computer or On a CD up 2X more.
    I hope you dont Work with IASCA in SQ.
    Or IDBL.
    still has losss
    nobody out here is in the world finals for SQ
    im shure of this.
    or you would not even have A car pc loaded with mp3's
    if your in the world of SQ. mp3 and alike are a sin.
