Results 1 to 10 of 11
Thread: PyCar- Linux car media system on bootable CD
    FLAC jbors's Avatar
    Nov 2003
    Guys,
    Just uploaded my first try in doing full featured linux build( don't beat me hard ). Check it out:
    https://sourceforge.net/project/show...ease_id=262479
    There are two files:
    - ISO is the regular image you can burn on a CD and boot from it( or place it on you CF/DOM )
    Contains kernel 2.4.23, DirectFB and pycar
    It supports only epia-m boards mainly because of DirectFB support.
    It is only 10Mb including everything you need. Just try it out and have fun.
    It boots in 15 secs after POST( from DOM, little longer from CD ), so you can get the whole thing working in 30 secs( 20 secs if you use linuxbios )
    - zip file which contains the same thing but on Windows, just unpack it to any place you like and run pycar.exe.
    You may need to change the file config.xml to modify the default settings such as codepages, media file locations, cache size, etc.
    You can find the list of all its features + screenshots on this web site:
    http://pymedia.sourceforge.net/pycar/features.html
    I'm still doing major redesign of pycar to have it more suitable for touchscreens and add HW DVD decoding on epia-m. I'll post some pics later this week with the functional prototype.
    Have fun,
    Constant Bitrate mookie's Avatar
    Oklahoma
    Ignore what was in this post.
    I was trying it on my main computer. Didn't read the part about the EPIA-M's only. Will it work on MII's?
    Edit again:
    Guess it won't work on EPIA-MII series. Either that, or it hates me.
    FLAC jbors's Avatar
    Nov 2003
    Quote Originally Posted by mookie
    Edit again:
    Technically it should. Can you explain what's not working ?
    Oklahoma
    It starts trying to load linux then just restarts the computer. I'l try to see what messages are comming out of it tomorrow. I already have my system up for the night.
    Jul 2004
    Had the same problem with early 2.6 kernels on MII board. A kernel update allowed our test systems to finally boot.
    FLAC jbors's Avatar
    Nov 2003
    What kind of fixes you've made for 2.6 ? Is it just processor code generation part or something more ?
    I cannot use any of 2.6 kernels atm since DirectFB does not pass all the tests and those kernels have internal problems with udf, viafb and others...
    Jan 2004
    I dont know what Direct FB is.... but is it possible that u could make it for all motherboards... not just EPIA's..????
    It would be awesome to just pop in a cd with a linux distro and ur program on it.... or even install it on the hdd
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    FLAC jbors's Avatar
    Nov 2003
    Quote Originally Posted by toadster123
    For generic solution you would need 300Mhz+ for audio/radio stuff, 1Ghz+ for DVD playback, 600Mhz+ for divx.
    You still have to know which mobo and chipsets you're using for audio/acpi/ide/network and stuff even if you use VESA. If you compile all those drivers and let kernel load them on fly, it will not be any different from Windows( 300Mb+ ).
    So I can create generic ISO without DirectFB involved( VESA+ SDL+ pygame instead ) so you can place your own kernel to keep it small...
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    It seems to keep reboot system after unpacking initrd on my system. (EPIA-M 10K). What CPU was the kernel set to (mine is C3-II - Nehemiah)?
    FLAC jbors's Avatar
    Nov 2003
    Quote Originally Posted by mpattonm
    The processor setting was C3-II. I'll borrow M10K from my friend and let you know when I have it working...
    Thanks,
  1. User help to design MP3 car CD radios
    By MP3Design in forum General MP3Car Discussion
    Last Post: 03-20-2006, 05:57 PM
  2. Car with no system..How do I wire the speakers to my MP3 system?
    By fogleroller in forum General Hardware Discussion
    Last Post: 02-14-2002, 03:46 PM
  3. mp3 car discussed in maximum linux
    By johna10093 in forum General MP3Car Discussion
    Last Post: 02-02-2001, 12:43 PM
  4. car cd player plays mp3 discs from kennwood
    By cadcam in forum General MP3Car Discussion
    Last Post: 09-04-2000, 11:28 PM
  5. Is this a good computer for a car mp3 system ?
    By mprover in forum General Hardware Discussion
    Last Post: 08-10-1999, 06:37 PM
