Results 1 to 3 of 3
Thread: WindowsXP vs. WindowsXP Embedded /CF card help
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    I know, both topics were discussed countless times.
    Still, I would like to have CF card as bootable drive. What can I use as OS: WinXP, WinXPE or Linux. WindowsXP still keeps writing to registry, ini files, logs, etc... you can turn off swap, but you will not eliminates writes. And it is known fact that writes kill CF card eventually. You are left with two choices: XPE or Linux on r/o partition.
    Because creating XPE image is just pure pain and you end-up with 120 days evaluation anyway. And the only thing you in fact need from XPE is EWF - Enhanced Write Filter, a piece of code that redirects all the writes to "black hole". The other efet of XPE (size) can be acchieved with nLite easily. Sooo... I was thinking about a little cheat: take a EWF component of XPE, extract its files and corresponding registry keys and import them to reg. WindowsXP (stripped down to minimum). What do you say to such idea? Any1 willing to do that, since I do not have my evaluation copy of XPE anymore?
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Quote Originally Posted by mpattonm
    You could also use XP pro, nlite and ReadyOn (will disable writes too)
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
    May 2003
    Czech rep.
    Does RadyOn disable writes during Windows runtime???
    By the way it seems I could not get single licece on ReadyOn here. I have been contacted by Czech partner of ReadyOn developer saying I would need developpers tools purchased (price 3k USD).
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. FS ATI Technology R360 graphic card
    By l4tran in forum Classified Archive
    Last Post: 08-14-2004, 10:37 AM
  3. WANTED: PSOne->gfx card cable & gfx card.
    By kerbdog in forum Classified Archive
    Last Post: 04-20-2004, 09:54 PM
  4. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 04:14 PM
  5. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
