Results 1 to 7 of 7
Thread: Two choice on boot up in wondows XP...help?
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Wiped the drive, and reinstalled xp home. Now when I start it up it gives me two choices. (Both the same) Xp home edition, or xp home edition. And it starts to count down from 26 sec.
    I always choose the 1st one. I don't want this any more!!
    Can you help me get rid of it?
    Obie one your my only help!
    BossTone74
    Jun 2004
    Seattle
    You bet... edit the boot.ini to get rid of the second option.
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    i believe you can go to a dos prompt and type "edit boot.ini" and remove one of the entrys for Windows Home. It doesn't sound like you "wiped the drive".
    Jan 2003
    Ruston, LA
    remember to make boot.ini not read only so you can edit it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Feb 2004
    Pittsburgh
    Right click my computer...properties...advanced tab...under startup and recovery click settings...choose the OS you want to get rid of, and uncheck the Time to Display Box...then change it to the default operating system install you want (if you want to keep your original installed OS then change it to the second, if you want to use the newer install leave it on the first)...click edit button...delete the corresponding OS line that you wanted to get rid of...badda bing close that and get out of your settings....maybe theres some extra steps in there that arent really needed or whatever but its what I know works
    May 2002
    Japan, Oregon
    Hey guys, thanks for the replies!!
    Kirk Frog, I did what you said...it worked!! It basically just help edit the boot.ini
    Thanks for the education!!
    I knew Frodo would pipe in!
    For some reason I feel like he is my computer guardian angle!
    BossTone74
    Jan 2003
    Ruston, LA
    Quote Originally Posted by bosstone74
    What would give you that idea ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Anyone looked into ReadyOn for XP boot?
    By gork in forum Software & Software Development
    Last Post: 01-12-2007, 09:48 AM
  2. CF Card for Windows XP OS boot???
    By englsh in forum General Hardware Discussion
    Last Post: 07-26-2004, 02:03 AM
  3. XP Embedded flash boot?
    By Shredder in forum General MP3Car Discussion
    Last Post: 02-26-2004, 05:04 AM
  4. windows xp scandisk at boot
    By Alives in forum Software & Software Development
    Last Post: 05-24-2003, 12:39 AM
  5. boot times with XP
    By Alives in forum General Hardware Discussion
    Last Post: 11-15-2001, 01:42 PM
