Page 1 of 7 1234567 LastLast
Results 1 to 10 of 61
Thread: Any success with Windows XP Embedded?
    Aug 2003
    and software (especially GPS)
    and final disk size (after basic software install)
    thanks!!!
    Constant Bitrate Needstorage's Avatar
    May 2004
    Belgium
    Quote Originally Posted by sirope
    thanks!!!
    I run Xp Embedded. It works fine. I have Destinator support, multimedia, a OBD-link and since yesterday I managed to get my USB bluetooth drivers on the XP embedded os. All works fine. What are your issues?
    I had some issues with the drivers for the USB bluetooth dongle and the drivers for the USB touchscreen. These all can be installed after your image is deployed, because they are way too big/complex to be componentized.
    My USB Bluetooth device (sitecom CN-500) uses the widcomm drivers. You can install them after the image is created and working, but you'll need to add support for Windows Installer into your runtime.
    And what do you mean by 'final disk size'? My OS is 200 Mb, without the maps for destinator.
    Needstorage
    Who the hell is general failure?!?
    And what the f@#k is he doing reading my drive C:\?
    Aug 2004
    Germany
    also thought of xp emebbed but i dunno where to get this damn systembuilder??
    btw i am MSDN Universal subscriber is it included there??
    Golf 3 CarPc Status
    ///////////////50%--------------/
    PSU:Inverter
    GPS:BT GPS
    PC: Slim notebook with 10.4"touch, external DVD.
    Dock for car is in production.
    Audio: Stock speakers but looking for new ones. CD-HU with FM modulator (ordered)
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Just downloading it myself (from ms website > windows > embedded > downloads ). Is there any recommended configuration I should use?
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    May 2004
    Belgium
    Quote Originally Posted by stevieg
    Yes, your own...
    What do you mean? The development system where you'll be creating your image? I use a P4-3 Ghz, FSB800, 1Gb ram, SATA disk. The Target Designer is pretty performance hungry. The loading of my build image into Target Designer takes approx. 20 secs. I'm sure it will work OK on a less powerfull system, but you'll have to be a bit pore patient.
    As for the destination device you want to use, the best practice to get something going is by installing a normal XP pro on to the device and gathering the system information using the tap.exe tool that's provided with the Embedded XP tools. The result file of this command line tool can be imported into the component designer, which allow you to create a component for your device that has all hardware dependencies in it. To downsize your image, remove all stuff from that component you will not need. Be carefull with this process and I advice you to do this in steps. Create a working image with your component, deploy and test. Remove some stuff, recreate image, deploy and test...
    If you have a blue screen while running the builded image the first time, it means that you have ignored some 'unknown hardware'. You'll have to supply drivers for ex.: Touchscreen, VGA, USB, ...
    Needstorage
    May 2004
    Belgium
    Oh, and another one... Start working on a 'basic' setup. Just make sure your image runs fine with the minimal components installed/plugged in to your device. After you have a working image, add another component, componentize the drivers for the component using the Component Designer, add it to your Target Designers image, deploy and test. If you design like this, you'll be safe and get a the most success.
    Needstorage
    Aug 2003
    Yes, final disk size is the windows xp + mp3 player + video player + gps soft and the required dlls.
    I'm looking this: http://h50025.www5.hp.com/hpcom/my_e...42_DC639A.html
    but I want to be sure before buy.
    The other option is to use my m10k with XPe image ( and DOM disk), but nobody share it (the XPe) although the basic hardware is the same: epia m10k
    May 2004
    Belgium
    Well, it's hard to share these images. You maybe have the same Epia board as someone else who uses XP embedded, but I'm sure you have some other peripherals that you will use. The basic image for a simple setup (Motherboard, Ram, Harddisk, VGA and keyboard) is not that hard to do. The peripherals are the hardest to do. So you will not gain a lot of time by using someonelse basic image. Just go ahead, and invest some time in it. My build -like it is now- has been changed approx. 50 times since I started from a basic setup. I've put a lot of work in it, success doesn't come easy, u know. I think I probably have been working 15 full days (120-150 houres) on just the XPE image, and I'm not even counting the research efforts, the proof of concepts, the front-end development and the wardware-install. I'm not even sure if I will still recognize my own wife in a couple of months...
    About the link you gave... I wouldn't buy that. It's pretty expensive and you'll need an invertor for it if you don't want to open the case if this thin client has a built in PSU. Invertors are BAD stay away from them! They are your worst nightmare. Just buy yourself a Via board and start rocking!
    Needstorage
    Aug 2003
    OK, i will use my epia m10k, thanks
    Newbie jcraig's Avatar
    Jul 2004
    Palmetto, FL
    I just downloaded it from m$ using the evaluation link. is that like a trial version? if so, can anyone hook me up with a fresh copy? PLEASE!?!?!?
    John Craig • '98 Cadillac Catera
    http://www.digitizelife.com
    8" Lilliput TS • VIA MII10000 C3 • 512MB DDR 2100
    160GB 7200RPM WD • Panasonic 24X24X24X8 CDRW-DVD
    XM Direct • Netgear WG511T 802.11g
  1. epia M 10000 AND WINDOWS XP PRO
    By Dluvr22 in forum Software & Software Development
    Last Post: 10-18-2005, 09:04 AM
  2. Running FrodoPlayer on Windows XP Embedded?
    By Lupo in forum FrodoPlayer
    Last Post: 07-23-2004, 08:50 AM
  3. Windows XP Embedded
    By farolfo in forum Software & Software Development
    Last Post: 05-05-2004, 04:36 AM
  4. PowerMate on Windows XP Embedded
    By JasonSurratt in forum Input Devices
    Last Post: 01-14-2004, 12:06 PM
  5. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
