Results 1 to 10 of 17
Thread: WinXP Hibernation Problems
    Jul 2004
    I have my carpc set up to go into hibernation. It goes into hibernation fine, but when I turn it back on it does a full boot instead of coming out of hibernation. I can't really figure out why. I have an EPIA MII10000 with a Morex 60w PS & Carnetix P1260. WinXP is set to go into Hibernation when the powerswitch is pressed. I had this working fine when I had it set up with an Opus 90w powersupply, but it doesn't want to work with the Morex/Carnetix combo. Any ideas?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    That's weird man.
    Tidder
    Try RevFE
    Mar 2004
    Marietta, GA
    Quote Originally Posted by jeremyp111
    I have my carpc set up to go into hibernation. It goes into hibernation fine, but when I turn it back on it does a full reboot instead of coming out of hibernation. I can't really figure out why. I have an EPIA MII10000 with a Morex 60w PS & Carnetix P1260. WinXP is set to go into Hibernation when the powerswitch goes on. I had this working fine when I had it set up with an Opus 90w powersupply, but it doesn't want to work with the Morex/Carnetix combo. Any ideas?
    jeremyp111.... I have the same problem. I too would appriciate a solution if anyone knows of something!
    -Thanks
    Sep 2003
    New Mexico, USA
    I've noticed sometimes my computer freaks out if I'm accessing the hard drive constantly like booting for instance. (only when the car's off and my voltage is lower than it should be) It causes freaky things with the power. What/how many drives do you have? CD-rom, hard drive, USB devices, etc. That's the best I know where to start man, sorry.
    Tidder
    Try RevFE
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    I’m using a inverter+itps and a amd board, but i very occasionally get the same problem. I found out that when power its shut down ( in my case, when the itps cuts the power to the relay that is between the battery and the inverter). The itps feeds a very small pulse to the output that is connected to the pc power switch. This sometimes is enough to make the pc start, and since its power is cut immediately after, when it boots again it no long resumes from hibernation.
    Don’t know if it's your case, but I thought you might want to explore the possibility.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Jul 2004
    Quote Originally Posted by Tidder
    Here's what I have:
    EPIA MB (as above)
    512mb ram
    (1) 2.5" 60gb HD
    (1) slim DVD
    wi-fi PC card
    USB GPS mouse
    USB gyration keyboard/mouse combo
    Lilliput USB touchscreen controller
    Lilliput is powered from 12v+ regulated from Carnetix P1260
    Jul 2004
    Quote Originally Posted by Bravellir
    I've watched it to see if anything funny was happening, but it does go into hibernation properly. Power is shut down shortly there after. Most of the time it looks like it's trying to come out of hibernation and then just goes into a full boot like it was never in hibernation. Do you think i should try to repair the XP installation?
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Does it still work ok with the powerswitch button?
    Low Bitrate l9nux's Avatar
    Aug 2004
    Sussex, UK
    I'm not 100% sure on this, but does the motherboard still need power whilst in hibernation? I know it does for stand-by, but if your power supply is completely powered off (rather than just the PC), then this might be the cause?
    -= I took the red pill =-
    Oct 2003
    Madrid
    Quote Originally Posted by l9nux
    They don't need power in hibernation.
  1. XMPCR has hibernation problems?
    By MikeH in forum FrodoPlayer
    Last Post: 09-24-2004, 11:08 PM
  2. GS Reciever, WinXP SP2, and Hibernation
    By captain_jim1 in forum GPS
    Last Post: 09-19-2004, 04:12 PM
  3. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  4. Problems Enabling Hibernation
    By divinity in forum Software & Software Development
    Last Post: 05-16-2004, 01:03 PM
  5. windowsMe hibernation
    By moahdib in forum Software & Software Development
    Last Post: 08-04-2000, 12:07 AM
