Want to try![]()
What language?
:edit: What programming language?![]()
I'm creating a new thread so I won't clutter 0l33l's "Voice activated navigation for routis!" thread.
I wrote my own voice recognition app using SAPI. It's generic and can be used in any application that accepts keyboard input. Features and the grammar XML can be found on my website: http://galant.circledplus.com/carpc/carpc_apps_vr.html I'll create a download link later tonight in case somebody's interested to try it out.
I have a few questions for NTurkey...
Is it possible to create adhoc attributes? Like <P myAttribute="fooBar" VALSTR="taskmgr.exe">task manager</P> I'm getting an error if I create an attribute it doesn't recognize. This is the reason why I just used the inner PROPNAME in the example below.
Also, is there a way to get the text at a particular <P> node? Like I want to get "task manager" (between the P tags, not the PROPNAME) from the above code.Code:<RULE NAME="runApp" ID="RID_RunApp" TOPLEVEL="ACTIVE"> <P>open</P> <L PROPNAME="runAppvalue"> <P PROPNAME="task manager" VALSTR="taskmgr.exe">task manager</P> <P PROPNAME="i Guidance" VALSTR="iGuidance">navigation</P> <P PROPNAME="Media Car" VALSTR="C:\Program Files\MediaCar\MEDIACAR.exe">media car</P> </L> <O>...</O> </RULE>
TIA
00 Galant
armadaE500 P3-660 320M 20G, lilliput, audigy2NX, slim/slotLoad dvd/cdrw, cardReader
sony rm-x2s, bu303, xmDirect
xpPro sp2, frodoPlayer 1.09, iGuidance 2.0, custom voiceRecognition
custom shutdownController
Want to try![]()
What language?
Installation: 90% complete - fiberglassing
EPIA M10000 - 512Mb - 20GB
Lilliput 7" TS - Opus 150W PCB - DLink USB Radio - slim CD-ROM - SoundBlaster MP3+ - not so crappy 40x4 Amp - BU303 GPS (waiting for) - BT support
VB.NetOriginally Posted by BeamRider
Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
www.aimee.cc
As far as an arbitrary attribute for the P element in SAPI's XML, no, you can't create arbitrary XML attributes. The SAPI compiler will complain.Originally Posted by djScript
In your example above, are you just trying to keep track of the application name, as well? If so, you could use something like this (you'll find two properties in the result, instead of just one ... one called AppToLaunch and one called AppName):
Code:<RULE NAME="GlobalApps" TOPLEVEL="ACTIVE"> <L> <P PROPNAME="AppToLaunch" VALSTR="taskmgr.exe"> <P PROPNAME="AppName" VALSTR="Task Manager"> Task Manager </P> </P> <P PROPNAME="AppToLaunch" VALSTR="C:\Program Files\MediaCar\MEDIACAR.exe"> <P PROPNAME="AppName" VALSTR="Media Car"> Media Car </P> </P> </L> </RULE>What language are you using? If you're using C++, you can get the ISpPhrase interface from the result, then you can call GetText.Originally Posted by djScript
To determine what the appropriate start and count would be, once you have the SPPHRASEPROPERTY, you can look at ulFirstElement and ulCountOfElements. You might have to change your grammar around a little bit, but not much.
Does that make any sense? I bet it doesn't if you're not using C++.![]()
2004 BMW 330Ci
Audio: Alpine PXA-H701, XTANT 1.1i, PPI 4800, MB Quart QSD 216, JL W6v2
Computer: Shuttle XPC P4 3GHz HT, 1G, 160GB HD, WinTV
Software: StreetDeck ... soon with wicked cool speech integration ...
Install (A/C/S): 100/100/90 %
Yes, which is basically the same as the command that's why I wanted to get the text between the <P> tags. GetText(FirstElement, NumberOfElements) seems to have did the trick and I didn't have to change the grammarOriginally Posted by NTurkey
I'm using VB.netOriginally Posted by NTurkey
Thanks.
00 Galant
The app can be downloaded from my website:
Just post here if you need help in grammar configuration.
00 Galant
Download link on website doesn't work for me.
Also, I'm moving this reply over to here from other thread:
Looks good. I saw that you're using MediaCar and thought I'd mention an idea I had for navigating between the audio, navigation, dvd, ect... portions since it didn't appear to me that keystrokes were supported. I just wrote tiny programs that send a single mouse click to the button of the area I want to navigate to. I'm sure somebody could write a program that would take a skin file and parse the information into lines ready to be coded into a program. Once again nice job!Originally Posted by djScript
Does it give you any error? 404? I tested it and it worked for me.Originally Posted by rgardjr
Try this:
VoiceRecognition
Let me know if that still won't work and I'll just attach the file here.
I updated the grammar and created a new rule to support sending mouse clicks. It will switch to the application window you want to control first before it moves the mouse and sends a click. I have some few commands for MediaCar's main menu buttons.Originally Posted by rgardjr
00 Galant
The above link worked great.Originally Posted by djScript
Wow! This is great news. Can't wait to get this in my car. What microphone are you using in your car and how good of job does it do?Originally Posted by djScript
00 Galant
