Results 1 to 10 of 10
Thread: Adjusting Volume Level According to Master Volume
    Constant Bitrate Xtreme2k2's Avatar
    May 2004
    NJ
    Alright, I was originally going to use the SPDIF out on the mobo, and go to the Creative DDTS-100, but I decided not to because I didnt like the fact of the external volume and the settings being lost when power is cut.
    Anyway, I have an M10000, and I'm using the audio driver version 3. something (I'll check when I get home), I have the Smart 5.1 enabled on the front speakers, and the Magic 5.1 enabled on the rear speakers, yet the drivers are coded so that the front are set as the master speakers.
    I was looking for a way to make a program that would run in the background, and monitor the front speaker volume level, and when it was changed, have the program change the rear speakers accordingly.
    Would this be possible?
    Also, I tried the newer drivers, and the Smart 5.1 / Magic 5.1 wasnt there, it wouldnt show the front, rear, center, or sub. Just the Master and such.
    What do you guys think? Would it be easy to accomplish?
    This can be done with Girder easily.. With a little playing around I made one on this machine that made the Wave Volume match the Master Volume slider. Since the numbers are different, it wouldn't work on the M10k, but I can make a girder file that will..
    Epia M10000, Custom enclosure, Starvision SP-VGAT, Linksys WUSB54G, Delorme Earthmate, Windows XP
    May 2004
    NJ
    Quote Originally Posted by Yang
    if you could, that would be awesome!
    Jan 2003
    Ruston, LA
    Code:
    © 2004 Kevin Lincecum
    © 2004 FrodoPlayer.com
    frodo {at|  frodoplayer.com
    Title: MatchVol
    Version: 1.0
    Purpose:
    Matches Wave Volume to Master Volume.
    Usage: Run matchvol.exe
    License: Unlimited for non-commercial use.
    Frodo
    Attached Files Attached Files
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2004
    NJ
    Quote Originally Posted by frodobaggins
    Code:
    Title: MatchVol
    Version: 1.0
    Purpose:
    Frodo
    Sweet, tho I want the rears to be adjusted when the front ones are.
    Anyway I can get the source code?
    Jan 2003
    Ruston, LA
    I thought your master was front and rears were wave ?
    What exactly do you need ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2004
    NJ
    Well, theres Front, Wave, Center, Sub, Rear, and so on.
    Heres a link to the install files for the audio drivers I'm using:
    http://www.xtreme2k2.com/AudioDrivers.zip
    Hope it helps
    I want the front and rear speakers to be the same.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Xtreme2k2
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2004
    NJ
    Hmm.. This should be fun figuring this out
    Its a bit more complicated then I thought it was
    May 2004
    NJ
    Alright, I'm an idiot.. I updated to the 5.50a drivers, and ran ADeck, and I could configure it in there... well I'm a dumbass
    Now if only I could get the sub to stay at max volume..
  1. master volume
    By funkeq in forum Input Devices
    Last Post: 10-11-2006, 08:04 AM
  2. Adjusting Wave & Main Volume Options??
    By xtreme_db in forum FrodoPlayer
    Last Post: 09-03-2004, 10:02 PM
  3. Balance and master volume interaction...
    By millovanillo in forum MediaCar
    Last Post: 08-16-2004, 01:22 PM
  4. Winamp controlling master Wave volume in windows??
    By Max018 in forum Software & Software Development
    Last Post: 03-22-2004, 02:36 PM
  5. The volume question: MASTER vs. WAVE
    By tbdombrosky in forum Software & Software Development
    Last Post: 07-19-2002, 03:59 AM
