Page 10 of 16 FirstFirst 12345678910111213141516 LastLast
Results 91 to 100 of 152
Thread: A/C and Heat controling software
  1. #91
    Low Bitrate khemical's Avatar
    Jun 2004
    DeKalb
    Quote Originally Posted by rkm625
    Is there a program out there that will control them? I looked around a lil bit but didnt see anything other than music/media software. thanks for helpin a n00b...
    OT: Atleast I am not the only person sport'n an 860 on here. hell, even glad to see another nextel user
    steve
  2. #92
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    Hey DjBac, i was about to start working on something like this using the parallel port, until I found this, which made me pretty freakin happy. The picture you showed on page 4 I think, is that the phidget board with a board you made with relays to control inputs and outputs? I am going to ask a stupid question, i want to be able to use a temp sensor, and was wondering how you did that. I ask that because you used the 0/16/16 that can't use the digital temp sensor, or did you use the USB temp sensor. Thanks for any help, its been awhile since I programmed in VB, but this is a good reason to start again. You should add this to "support software" and ask for donations or somehwere else. I think this is something everyone can benefit from that has to remove some buttons or options on the car when mounting, and just to do some really cool things.
    Nice work so far, and if you need some help, because I got lots, let me know.
    later
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
  3. #93
    Oct 2003
    Chicago, IL
    I am very close to having this working for my car, i post about it on my site http://www.smokinmhz.net
    i am using 2 stepper motors, a parallel board to control them, a crystalfontz 633 for user info/input and the temperature sensors, a circuit to interface with the OEM climate control PCB and Fan switch, and i am currently writing the software in C#
  4. #94
    Jan 2005
    Indiana USA
    here is my HVAC interface
    i used the Brushed Alum. Skin style b/c i'm using it in Centrafuse but need to figure out how to imbed the program.
  5. #95
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    nice setup. props to ya :thumbsup:
    Your everyday carpc geek and tech guru at your service. *bow*
  6. #96
    Oct 2003
    Chicago, IL
    that looks really nice, man
  7. #97
    Jan 2005
    Warren, Ohio, USA
    well, i was just playing around with visual basic a bit and have found out how to get a semi-original gui going using some clipped parts from codesters screen above for a testbed. so far ive been able to get the background in and a button and make it all look clean. just the title bar and window outline i havent been able to find out how to remove yet.
    my question is though, how hard has it been for you guys to integrate phidget control into a vb.net application? is it as simple as entering code like this into the mix?:
    Code:
    onclick.btnfanspd1 {
         phidget1.move.25 }
    or is it a bite more complex?
  8. #98
    Jan 2005
    Houston
    Man thats nice
  9. #99
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Looks great! This gives me the idea to do the same, and just hack and solder into the climate control. But the problem is that I'd need 2 kits... 1 being the 0/16/16, the other being 8/8/8. My car has 10 buttons on the AC, so the 8/8/8 will not be enough But hey, its cheaper than getting a new peice
  10. #100
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by clean customs
    later
    Well, I use 2x0/16/16 and 1x8/8/8 for the moment... But I will need one more 8/8/8 since 5 of my leds in the HVAC board that tell you if A/C or rear froster etc are on ive an output bellow 3.5 so I can't use 0/16/16's inputs... I had to use 8/8/8's analog sensors... So I will need one more for the 2 temp sensors (more to come), light sensors and a lot volt sensors...
    I think it is difficult for someone to publish it's soft, since the functions are unique ofr every car model!!
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 11:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
