Page 11 of 16 FirstFirst ... 2345678910111213141516 LastLast
Results 101 to 110 of 152
Thread: A/C and Heat controling software
  1. #101
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by DjBac
    Well, I use 2x0/16/16 and 1x8/8/8 for the moment... But I will need one more 8/8/8 since 5 of my leds in the HVAC board that tell you if A/C or rear froster etc are on ive an output bellow 3.5 so I can't use 0/16/16's inputs... I had to use 8/8/8's analog sensors... So I will need one more for the 2 temp sensors (more to come), light sensors and a lot volt sensors...
    I think it is difficult for someone to publish it's soft, since the functions are unique ofr every car model!!
    Now way to amplify the voltage below 3.5 to above 4
  2. #102
    Jan 2005
    Indiana USA
    thanks.... the spaces beside the temp and and above the AC are the displays for the front and rear temp readings and the fan speed. Since my controls are all analog with my unit i will have to go with the 4 servo controller from phigets. The vents are controlled by a vacuum, temp by a cable, and the fans are controlled by current but i already have more than 8 relays i need for the relay board. Sucks that i have to work around this cheap car. LOL
    Does anyone know where i can find a servo that turns over 180* b/c you need to turn the temp knob way over 180 on both cold and hot side. And since it takes a little effort to turn then prob needs to be a high torque servo
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    I think most of the servos can be modified to turn up to 360 but you sucrifice speed (you don't care for this application)
    http://www.helicamsolutions.com/html/broadcast360.html
  4. #104
    Jan 2005
    Indiana USA
    but can you still program the servo to turn more than 180 with the phigets controller bc i think i once read that it can only go up to 180 with their controllers.
  5. #105
    Oct 2003
    Chicago, IL
    why not use stepper motors?
  6. #106
    Jan 2005
    Indiana USA
    are they easier to control and program then servos and are they strong enough to move a knob like that?
  7. #107
    Jul 2004
    Berkeley, CA
    Here's waht I hope my AC controller will look like. Suggestions, comments, etc welcome... also I need to know were to get high qulity images in the LCD
  8. #108
    Oct 2003
    Chicago, IL
    Quote Originally Posted by codesterZ24
    they are not easier to control than servos. You will need to find or make a controller. I have a parallel port controller. the nice thing about steppers is that they have full 360 degree motion and you can control and know the exact position of the shaft. read up on steppers and you will undestand.
    i tried to interface the stepper to my knobs but it did not work out, needed alot more torque, so i got rid of the whole thing and interfaced directly to the moving parts. I added a gear to the part that was driven by the rigid wire and installed my motor there.
    http://www.smokinmhz.net/modules.php...article&sid=22
  9. #109
    Jul 2004
    Berkeley, CA
    Hope this looks better
    I do wish that I could make it into something universal, but everyone's HVAC system is different
  10. #110
    Jun 2004
    GREECE/Athens
    Does anyone know if there is a way to implement my clima's LCD with the PC??
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 11:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
