Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 152
Thread: A/C and Heat controling software
  1. #21
    Whistle Tip pimpJ's Avatar
    Metro, TX
    you could just get fast ones and a gearbox.. right ?
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  2. #22
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    There is no need to get fast ones!!! The HIGH torque that are not fast, in fact are fast for this application but not fast enough for i.e. a helicopter tail!!! So no worry!!
  3. #23
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    I fly all types of R/C planes and helicopters. You should be able to get a servo that should do the job for about $30-40 if not less. The servos that cost $100 would be total overkill. They are fast and have high torque but really to much servo.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
  4. #24
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    How did you get the wiring diagrams/data bus for your climate control unit? How are you controlling the fan speed?
    [Edit]: How are you setting/reading the temperature?
  5. #25
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    I found some nice motors for the knobs i think:
    Minebea PM35S-048-AXB6 stepper
    Bipolair
    Voltage 24V
    Resistance 6.6 Ohm/Phase
    Step Angle 7.5 Deg/Step
    Gearmodule 0.4 with 12 teeth
    I mailed the owner about the speed and force and if you can control the position of it.
    Its only 2 so i dont think it will help :P
  6. #26
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by 0l33l
    I've just soldered the outputs from the phidgets to the A/C board... It uses switch to ground, as phidgets do.. But I needed some switches to +12V so I used relays.. Also some LEDs on the clima turn on at 1,1v (less than 5v phidget sees it as OFF) so I had to use omp-amps!!
    I think within the next week it should be installed!!
    About the motor.. Step Angle 7,5 deg/step (it depends on ur knob)
    24V (no good)..
    If you get the 1-servo controller from phidgets you need NO extra power..
    This motor cannot be controlled from this board!!
  7. #27
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by DjBac
    24V (no good)..
    My car has climate control with a digital LCD display, so I doubt I could hack into its data bus and modify commands. I'll forego this and just hack up my current C/C because tis LCD is all fuxored up (LCD bleed). I'll properly mold it into the dash and get a new one
  8. #28
    Raw Wave lostreception's Avatar
    NY
    My van has 2 small sliders similar to this but not quite
    can phidgets be used to control this?
    my assumption.. probably not
    mostly because its vacuum controlled as far as the heat to cold ratio
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
  9. #29
    Jan 2003
    Ruston, LA
    Quote Originally Posted by lostreception
    Yes. Just not directly. You can use the phidget servo controller.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #30
    NY
    Quote Originally Posted by frodobaggins
    will it require changing the slider or resoldering the terminals
    for eg. which phidget would i use a relay serial conroller type?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 11:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
