Page 4 of 16 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 152
Thread: A/C and Heat controling software
  1. #31
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    You can use relay board to control this thing right?
    Toyota Supra (89-92) HVAC control.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #32
    Low Bitrate megamind's Avatar
    Aug 2004
    Netherlands, Rotterdam
    Ok i got something else (cheaper )
    http://www.vandijkenelektronica.nl/s...ages&index=548
    Its a stepper motor, 9v but works perfect on 12v, uses a 1$ ULN2003 and it can connect 3 motors to 1 paralelport. Gives lotsa force and only 7 degress per step, very accurate
    Might install them in my own car too..
  3. #33
    FLAC alti's Avatar
    NY
    Please forgive the noob question... but does anyone have a picture of servos hooked up to there HVAC or does anyone have any pictures at all of a relay settup for controlling their cars controls??
    Thanks in advance
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #34
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by 0l33l
    My car has climate control with a digital LCD display, so I doubt I could hack into its data bus and modify commands. I'll forego this and just hack up my current C/C because tis LCD is all fuxored up (LCD bleed). I'll properly mold it into the dash and get a new one
    I tried to interface my LCD too.. I think it can be done but it is a pain in the a**.. So I will just fabricate the LCD!!
  5. #35
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by alti
    Thanks in advance
    I hope I will get you some this week!!!!
    I should install it within the next days!!!
  6. #36
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by megamind
    You can turn down the voltage from phidget by decreasing the speed!!!
    The speed is controlled by voltage..
    But in the software you shouldn't overide 9V!!!
    About the sliders and servos...
    Think what they use on R/C's...
    i.e. to turn the wheels!!!
    So, yes you can do it...
  7. #37
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Have you implemented this yet??? Anyone??
  8. #38
    Variable Bitrate Goose's Avatar
    Dec 2002
    Europe
    You can use a pararell port to controll 8 relays.
    I got a PCB and the component list that is needed to this...
    Also easy software to controll 8 ports (high/low)
    Maby it could be a next future in frudoplayer?
  9. #39
    Variable Bitrate Leddy's Avatar
    Mar 2004
    My project has been on the back burner for quite some time. I unfortunately lost a hard drive with it all of my source code. I haven't had the desire to continue with it at this point because of that. I also have soooo many other things going on I haven't had the time. I will get to it eventually.
    I am able to control 6 relays(all I needed) via a microcontroller through the serial port. I liked serial because of the usb->serial connectivity if I needed an extra for something else. Serial real estate isn't cheap
    I personally prefer this method to any of the off the shelf products as it is catered to my needs not "the masses". To help anyone along attached is the schematic I used. Never corrected schematic it's a 220 Ohm resistor, not 680.
    2001 Pontiac Grand Prix GTP Sedan (Sold)
    2007 Scion tC
    WhereIsMyGPS.net Online Tracker
    http://www.cardomain.com/id/leddy
  10. #40
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    would it be posible to connect a thermometer and have the computer calculate everything necissary to keep the car at that temp...
    So if you have set to 70* F and its 80* F the comp would turn the air up until it reaches desiderd temp.
    Would this be possible?
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 11:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
