Page 5 of 16 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 152
Thread: A/C and Heat controling software
  1. #41
    Variable Bitrate Leddy's Avatar
    Mar 2004
    This applies to everything...
    Anything is possible given enough money and time
    Yes they have temp sensors that can be read by microcontrollers. The hard part will be the "logic" behind it all as that is all done by code.
    2001 Pontiac Grand Prix GTP Sedan (Sold)
    2007 Scion tC
    WhereIsMyGPS.net Online Tracker
    http://www.cardomain.com/id/leddy
  2. #42
    Oct 2004
    Worcestershire
    Has anyone concidered using some of the small PLC's like Allen-Bradleys Micrologix or CompactLogix. Programming of Inputs and Outputs is a doddle with ladder logic. CompactLogix has PID control that would be good for temperature control via analogue I/O, serial port can be used to interface to PC
  3. #43
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Here is an update!!!
    Ignore INSIDE TEMP reading and appearance!!!
    A/C works fine.. Having problem with Alarms (Hazard) when the PC shuts off/hiberantes.. But with the use of 2 relays it will be solved!!!
    From the hardware part I am working on lock/unlock, windows, shock absorbers, auto lights (depending on lighting), auto hazard when hard braking, engine start for i.e. 3 minutes when voltage drops etc etc....
    There is still WAY to go!
    All button letters light blue when light turn on to much car interior.. Also the "leds" turn on!!
    The background is temporary!!!
  4. #44
    FLAC alti's Avatar
    NY
    that is sweet!
    love the look of the buttons looks stock toyota.
    do you have any pics yet of the actual relays on the HVAC controls? i am curious how they hook up..
    thanks
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  5. #45
    Jun 2004
    GREECE/Athens
    Thanx!!
    On the left is the phidgets, middle a realay card I made to connect to phidgets for more safety (especially for grounding different things) and on the right the A/C pcb the car has!!
  6. #46
    FLAC alti's Avatar
    NY
    thanks, i have ordered a breadboard and some grab bags of stuff from jameco and am going to have a go at this myself after playing around with it for a while
    nice job
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
  7. #47
    Mar 2004
    Quote Originally Posted by DjBac
    Thanx!!
    Where did you get those solderless green connectors? Any P/N's?
    2007 Scion tC
  8. #48
    Variable Bitrate HybridFox's Avatar
    Oct 2004
    Peterborough/Ontario/Canada
    woops sry im crazy
    that wasnt the right info
  9. #49
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Quote Originally Posted by Leddy
    At my work we use those solderless green connectors made by Phoenix
    http://eshop.phoenixcontact.com/phoe...n.com&login=no
    go to COMBICON and then PC TERMINAL BLOCKS
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
  10. #50
    Nov 2004
    Quote Originally Posted by SICK J
    Using AB stuff would be kinda pricey wouldnt it?
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 10:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 12:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 09:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 02:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 08:18 AM
