Page 8 of 16 FirstFirst 12345678910111213141516 LastLast
Results 71 to 80 of 152
Thread: A/C and Heat controling software
  1. #71
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    splendid. has anyone managed to get this fully working with old school analog controls? if so, mind taking a video of it in action (if possible)?
    id definitely be interested in this. if anyone has ever seen the dash of a 96 windstar (check some of my previous posts), even with the headunit removed, there is no room to embed a screen in there. so basically the hvac system either needs moved or removed. needless to say, this would be PERFECT.
    add support into centrafuse and it would be a godsend
  2. #72
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Vinister
    How hard would it be to use one of these rotary encoder fidgets to control the volume? I've been missing my volume knob every since going to carpc. Everything else can be touch, but the volume, geez, it just has to be a knob.
    I assume it would be easy enough, but, would it work with frodoplayer and everything?
    Vin
    Its not that hard
  3. #73
    Jan 2005
    Warren, Ohio, USA
    i was just looking into that phidgets site and it looks like the perfect solution for this application. usb, up to 4 servo's on a single card (which should be enough for most systems. i know that the one that ive got has 4 controls and one is strictly for the rear seat fan), the servo's are powerful enough for all hvac systems (they should be anyhow. if not its gotta be a PITA to turn those things), and with the right setup, a servo can easily be used for those older hvac systems with sliding controls.
    but the problem im seeing is the price. $60 USD for the interface? maybe if this was homebrewn (which i doubt, but feel free to prove me wrong) it would be justified. but in any case, does anyone know of a similar system thats cheaper? even if it was serial or parallel based, it would work.
    thx
  4. #74
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Vchat20
    That's a bargain for the quality and useability of phidgets.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #75
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by frodobaggins
    I second that!!!
    The quality is very good... I've tried some more serial interfaces.. The quality/size is definately different!!
  6. #76
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by DjBac
    auto engine start when I want to and voltage is bellow 11,2v for 3min,
    Awesome. How did you manage that?
    no time for something else as I am in the exam period!!!
    I hear you..me too.
  7. #77
    Jun 2004
    GREECE/Athens
    Quote Originally Posted by Cris
    I hear you..me too.
    I used the volt meter phidgets has and some relays and programming!!!
  8. #78
    Feb 2005
    What was the purpose of the Relay board again? I know u said for extra grounding etc. but still not sure about the exact purpose. Sorry for the silly question but it's been 20 yrs plus since I dabbled with electronic circuit boards etc. Can you provide any more specific specs on the relay board ie; ratings etc.?
  9. #79
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Dark_Falcon
    Relays to press buttons.
  10. #80
    Jan 2005
    Warren, Ohio, USA
    yeah. for example, alot of newer cars either the majority of the hvac controls are electronic, or all of the hvac controls are electronic. a relay board would work a hell of alot better in this case than a servo controller.
  1. Neat idea for heat control
    By kefka_killer in forum General Hardware Discussion
    Last Post: 08-17-2004, 11:36 PM
  2. Heat problems??
    By TheKurbster in forum Software & Software Development
    Last Post: 05-22-2004, 01:19 PM
  3. To heat sink or not to heat sink ...
    By jnusaira in forum Newbie
    Last Post: 02-18-2004, 10:46 AM
  4. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
  5. COOLING THE CARPUTER
    By moahdib in forum General Hardware Discussion
    Last Post: 07-04-2002, 09:18 AM
