Results 1 to 10 of 12
Thread: Listing Database Info troubles
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Question Listing Database Info troubles
    Im trying to display the info i have in a databse. For example when i retrieve data from a field called "Artist" and i get the listing of Artists but the same name will show repetitavly. How can i get the artists to show once in the listbox or listview? Hope someone can help.
    Thanks in advance.........
    Whistle Tip pimpJ's Avatar
    Metro, TX
    in what program/language ?
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Programming Language
    Quote Originally Posted by pimpJ
    Oh Sorry VB6
    Metro, TX
    I think some of your code would be necessary in order to really answer your question. I don't know VB6 anyways.. so
    www.neoterikos.com
    Jan 2003
    Ruston, LA
    post it. I'll show you
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Quote Originally Posted by frodobaggins
    Set rs = New ADODB.Recordset
    If Option1.value = True Then
    rs.Open ("select * from media where Artist like '" & Text1.Text & "%' order by artist"), dbCon
    While Not rs.EOF
    lstMedia.AddItem rs("Artist")
    rs.MoveNext
    Wend
    rs.Close
    Set rs = Nothing
    End If
    LstMedia is a simple listbox. Should i be using somthign else instead like a listview or grid possibly?
    Thanks frodo.....
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    You will want to do the following:
    rs.Open ("SELECT DISTINCT artist FROM media WHERE artist like '" & Text1.Text & "%' order by artist"), dbCon
    While Not rs.EOF
    rs.MoveNext
    Wend
    rs.Close
    Set rs = Nothing
    End If
    This should then only pull out the unique artists that match the description
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    (6) is offline
    Newbie (6)'s Avatar
    Oct 2004
    Quote Originally Posted by Confused
    Garry
    Thanks alot that works
    Aug 2003
    Essex, England
    Not a problem, glad I can help
    Garry
    www.aimee.cc
    Jan 2003
    Ruston, LA
    Bastard I was asleep !
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Replies: 13
    Last Post: 09-23-2006, 11:34 AM
  2. Database build question
    By tmar89 in forum Media Engine
    Last Post: 08-17-2004, 12:21 PM
  3. Adding songs to database question
    Last Post: 07-03-2004, 04:40 PM
  4. Why use a database?
    By Noble in forum Media Engine
    Last Post: 05-18-2004, 03:32 PM
  5. a database of id3 info
    By etrik in forum Software & Software Development
    Last Post: 01-18-2001, 11:45 AM
