Ok, Here it is (it's not commented well) but again, its all prototyping.
Code:
Dim current_volumeLevel As Integer
Dim fso As New FileSystemObject
Static say_again As Integer
Dim hypoth As String
Dim hypoth_str_state As String
Dim b As Integer
Dim str_data As String
Dim pntr As Integer
Dim c As Integer
Dim d As Integer
Dim data_array1(50) As String
'Dim data_array2(10) As String
Dim data_array1Size As Integer
Dim data_array2Size As Integer
Dim var1 As String
Dim var2 As String
Dim x2 As Integer
Dim x3 As Integer
Dim var3 As String
Dim compentcy_score As Integer
Dim percentage_correct As Double
Dim compare As Double
Dim place_holder As Integer
current_volumeLevel = media_player.wmpplayer.settings.Volume
media_player.wmpplayer.settings.Volume = 0
' mute media player volume
begin_mp3Select:
If fso.FileExists(App.Path & "/grammer/mp3grammer.xml") Then
If say_again > 0 Then
speak ("Say that again ?")
Else
speak ("What shall I do ? ")
End If
media_search.myGrammar.CmdLoadFromFile App.Path & "/grammer/mp3grammer.XML", SLODynamic
'this statement plays the beep, loads the grammer file and activates recognition
Else
'If grammer file is not created, create it then call this function over again.
Call write_XML_MP3Grammer
GoTo begin_mp3Select:
End If
Dim initial_time As Double
Dim current_time As Double
Dim duration_time As Double
initial_time = Timer
media_search.reco_end = False
'waits 3 seconds to listen to command
media_search.myGrammar.CmdSetRuleIdState 0, SGDSActive
Do While media_search.txt_search.text = ""
DoEvents
current_time = Timer
duration_time = current_time - initial_time
If duration_time > 3.5 Then
GoTo done:
End If
Loop
done:
Do
DoEvents
Loop Until media_search.reco_end = True Or duration_time > 2.5
media_search.myGrammar.CmdSetRuleIdState 0, SGDSInactive
'inactivate voice recognition
'Process information
Dim primary_detection As Boolean
Dim recognition_string As String
If media_search.txt_search.text = "" Then
primary_detection = False
recognition_string = media_search.release_hypothesisPhrase
Else
primary_detection = True
recognition_string = media_search.txt_search.text
End If
If InStr(recognition_string, "by") Then
If InStr(recognition_string, "play") Then
voiceCommand = command_songby
GoTo SelectCommand:
End If
End If
GoTo SelectCommand:
End If
If InStr(recognition_string, "Show artist") Then
voiceCommand = command_showArtist
GoTo SelectCommand:
Else
voiceCommand = command_null
End If
SelectCommand:
'recognition_string = holds the data to be processed.
Dim command_playby_bypos As Integer
Dim songname As String
Dim artist As String
Dim i As Integer
Dim X As Integer
Dim playsong As Boolean
Dim str1 As String
Dim str2 As String
Select Case (voiceCommand)
Case (command_null)
' No command was initiated
If say_again = 1 Then
speak ("No command was heard.")
say_again = 0
Exit Sub
Else
say_again = say_again + 1
Call Voice_mp3_select
End If
Case (command_songby)
' "play & by"
command_playby_bypos = InStr(1, recognition_string, "by")
songname = Mid(recognition_string, 1, command_playby_bypos - 1)
songname = Right(songname, Len(songname) - 4)
artist = Mid(recognition_string, command_playby_bypos + 2, Len(recognition_string))
'From recognition
songname = Trim(songname)
artist = Trim(artist)
If primary_detection = True Then
For i = 0 To media_search.mp3_list.ListCount
If InStr(1, LCase(media_search.mp3_list.List(i)), artist) Then
If InStr(1, LCase(media_search.mp3_list.List(i)), songname) Then
playsong = True
GoTo playthesong:
End If
End If
Next i
Else
'working with a hypothesis statement here
'80's - Jefferson Starship - We built this city.mp3
End If
Case (command_song)
'play
songname = Mid(recognition_string, 5, Len(recognition_string))
playsong = True
GoTo playthesong:
End If
Next i
Else
'Working off of a hypothesis statement
'Scan list for instring of the songname
If InStr(LCase(media_search.mp3_list.List(i)), songname) Then
data_array1(c) = media_search.mp3_list.List(i)
c = c + 1
End If
Next i
'process the data
For i = 0 To c - 1
x2 = 1
Do
var2 = Mid(data_array1(i), x2, 1)
If var2 = "-" Then
x3 = x2
End If
x2 = x2 + 1
Loop Until x2 = Len(data_array1(i))
var2 = Mid(data_array1(i), x3 + 1, Len(data_array1(i)))
var2 = Left(var2, Len(var2) - 4)
'var2 is = confessions pt2
'MsgBox var2 & vbCrLf & hypoth
var2 = LTrim(var2)
x2 = 1
Do
var1 = Mid(var2, x2, 1)
If x2 > Len(songname) Then
'compentcy_score = compentcy_score + 1
Else
var3 = Mid(songname, x2, 1)
If LCase(var3) = LCase(var1) Then
End If
End If
x2 = x2 + 1
Loop Until x2 = Len(var2)
percentage_correct = (compentcy_score / Len(var2))
If percentage_correct > 0.6 Then
If percentage_correct > compare Then
compare = percentage_correct
place_holder = b
End If
End If
Next i
'media_search.lstmenuitems.Clear
If data_array1(place_holder) = media_search.mp3_list.List(i) Then
playsong = True
GoTo playthesong:
End If
Next i
End If
Case (command_showArtist)
Dim showArtist(100) As String
'Show Artist
artist = Mid(recognition_string, 13, Len(recognition_string))
If X < 100 Then
showArtist(X) = Return_Mp3(media_search.mp3_list.List(i))
X = X + 1
End If
End If
Next i
'MsgBox showArtist(1)
Else
End If
GoTo showArtistC:
End Select
showArtistC:
If voiceCommand = 0 Then
media_player.wmpplayer.settings.Volume = current_volumeLevel
Exit Sub
End If
If voiceCommand > 0 Then
say_again = 0
End If
If showArtist(b) = "" Then
speak ("Artist not found")
Exit Sub
End If
media_list.lstmenuitems.Clear
Dim additem As Boolean
For b = 0 To X - 1
media_list.lstmenuitems.additem (Return_Mp3(showArtist(b)))
Next b
For i = 0 To media_search.mp3_list.ListCount - 1
str1 = Return_Mp3(media_search.mp3_list.List(i))
For b = 0 To X - 1
str2 = showArtist(b)
If Not str1 = str2 Then
additem = True
Else
additem = False
b = X - 1
End If
Next b
If additem = True Then
media_list.lstmenuitems.additem str1
End If
Next i
