Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: Telematics.net
  1. #31
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Not a bad idea, when I get some spare time. I'm going to do it.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  2. #32
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    do it. now, *****!
    CarPC install is starting to come along again...
  3. #33
    Whistle Tip pimpJ's Avatar
    Metro, TX
    wow, I could have sworn I was the only person who even had VB.net. good to know there are others
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
  4. #34
    Metro, TX
    any convienient resources on handeling wmp in vb.net ? (I'm pretty new at it. It's no java)
    www.neoterikos.com
  5. #35
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    The WMP SDK has examples in vb.net IIRC.
  6. #36
    Jun 2004
    NH
    I'll be posting examples soon on how to do basic media handling with .net and WMP. (Be patient I've been perty busy the past few days)
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  7. #37
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Nice to see some VB.Net stuff. I took an entry level VB.Net class last spring hoping to beable to customize some stuff, but didn't really learn as much as I thought I would. Since most of the VB programmers around here are using VB6 I didn't really try and hack anything together, but now I might start playing around again.
    '03 Sierra Denali
  8. #38
    Jun 2004
    NH
    Ok, for those of you new to programming and VB.net. When designing your applications think about creating an MDI application (Multiple Document Interface) Where you have one parent form with many child forms. This will eliminate a bunch of headaches.. Here's how to create Parent / Child relation Ships in .net
    Main form Properties-> isMDIcontainer = TRUE
    Sub createChild(byref Frm_Parent as FORM)
    dim child_form as new form2
    child_form.parent = frm_parent
    child.show()
    End if
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  9. #39
    May 2004
    Arkansas
    sapi code please You can PM me if you wish. Gr4yscale on AIM too. I did find a decent SAPI example on PSC earlier but i haven't had time to look into it. But i think it may get me started.
  10. #40
    Oct 2004
    Long Island, NY
    Quote Originally Posted by pimpJ
    Just check out the WMP9/10 SDK - there are VB.NET examples and things to look at.
    But WMP is very simple to use - to play a file, just do this:
    Install WMP SDK; go to your toolbox -> add items -> then add the Windows Media Player control to your toolbox.
    Drag one onto your form.
    'wmpPlayer is the WMP that you've just dropped into form
    wmpPlayer.URL = "c:\mySong.mp3" ' or a wav or midi or anything else that WMP can play
    wmpPlayer.controls.Play()
    'to pause
    wmpPlayer.controls.Pause()
    'to stop
    wmpPlayer.controls.Stop()
    'volume (this is WMP volume, not system volume)
    wmpPlayer.settings.volume = 50 'values: 0-100
    'mute (again, WMP volume control, not system)
    wmpTemp.settings.mute = True
    Title = wmpTemp.currentMedia.name 'get media title
    FileURL = wmpTemp.currentMedia.sourceURL 'get media URL
    Artist = wmpTemp.currentMedia.getItemInfo("Artist") 'get any other kind of data in file
    Album = wmpTemp.currentMedia.getItemInfo("Album")
    Note: under VS.NET 2003, all the controls (play, pause, stop, etc.) are under wmpPlayer.Ctlcontrols -- e.g. wmpPlayer.Ctlcontrols.play()
    So that's basic operation - check out the SDK help and examples for more info on playlists, etc.
    Hope this helps
    Edit: Also, if you have questions regarding VB.NET, check out VBCity forums:
    http://www.vbcity.com/forums/forum.asp?fid=15
    --ABakshi (A+, MCSE, MCT, CCNA, CCNP, CCDA, CCDP)
    TechAutos.com (down for upgrades)
    Via M10000N Mini-ITX ////
