Results 1 to 10 of 10
Thread: Change Routis Com Port to 10?
    Maximum Bitrate riddle14's Avatar
    Aug 2003
    TN
    I have had a NAVMAN Usb GPS for the longest time and decided to got to a Bluetooth GPS. This is great and all except that I now can't use Routis because the Com port for the bluetooth adapter is 10 and Routis only goes up to 9. Does anyone know how to change it to look on com port 10?
    "I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
    By "ToneRiddle"
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    add a minus 1 to it? Wow that is interesting. Put a tech call into Deluo for that one.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Aug 2003
    TN
    i might just have to do that. was hoping someone else had run into this problem before???
    By "ToneRiddle"
    Jan 2003
    Ruston, LA
    why don't you change the com port on the bluetooth device ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    What ver of Routis? I am running iGuidance 2 (same as Routis 2004) and it shows 16 com ports.
    You could try GpsGate (http://franson.biz/gpsgate/) to redirect your com 10 data stream to another open port.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    iGuidance 2 is not Routis 2004, iGuidance 1 is. 2 is supposed to be the same as Routis 2005, if and when it ever comes out.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    You could also run a software COM port splitter, have that read COM10 and share it as a lower numbered COM port. Something like comfoolery, there are others too.
    Chris.
    Oct 2003
    Quote Originally Posted by dodgetimes2
    Your right... I knew that. sorry.
    Aug 2003
    TN
    how would i change the com port of the bluetooth device? would it be in the settings cause I looked all around and all I found was a drop down box with com port 10 and nothing else...
    By "ToneRiddle"
    Jan 2003
    Ruston, LA
    Quote Originally Posted by riddle14
    I would assume device manager.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Replies: 2
    Last Post: 12-17-2004, 02:27 PM
  2. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
  3. Replies: 10
    Last Post: 06-08-2004, 05:38 PM
  4. Working out the bigs with MC and Routis
    By shakes in forum MediaCar
    Last Post: 03-26-2004, 02:31 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
