Results 1 to 10 of 17
Thread: quick vb.net and wmp ?
    Whistle Tip pimpJ's Avatar
    Metro, TX
    I'm looking to create a sort of equilizer in a vb.net program. I'm using the wmp 10 SDK and I can't seem to find anything to accomplish this. I realize I could make a custom visualization to do it, but I don't really want to go to the trouble to learn how to do that. I'de like to keep it in vb.net, any help is appreciated.
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    There's not much documentation out there for making advanced options like that. At least as far as I've come across. I think media player does all the equalization internally..
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Metro, TX
    shux.
    anybody know differently ?
    www.neoterikos.com
    Metro, TX
    Ok, aside from an equalizer, what about just a visulalization. Can I get the current volume of 31hz, 62hz, etc. ?
    www.neoterikos.com
    Metro, TX
    Ok I think I got confused and possibly confused others in the process..
    what I'm looking for is 2 things (both through the wmp 10 SDK)
    1.) an equalizer in VB.net - which would allow me to change the volume of different frequencies.
    2.) The ability to make a visualization THOROUGH VB.NET. I realize you can show vis.'s or make custom ones in other programs. But I want the ability to make a visualization real time in VB.net. No other programming language neccesary.
    Tell me if I need to clarify
    www.neoterikos.com
    Jan 2003
    Ruston, LA
    Quote Originally Posted by pimpJ
    Not possible. Microsoft will not let you have access to it. I believe it
    is a licensing issue, as they licensed it from someone else.
    Have you looked at MSDN ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Metro, TX
    I was hoping you would answer.
    licensing on equalizer seems rediculous (I'm not doubting you, it just seems stupid)
    I'll read through the MSDN stuff about it tommorow. thanx.
    www.neoterikos.com
    Metro, TX
    I'll look further into the TimedLevel structure specifically waveform. Am I headed in the right direction ?
    (this was wm9 that I'm looking at. outdated ?)
    www.neoterikos.com
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    It is possible, Ive done it, just not from VB. You can do it in a C++ application by implementing a remoted skin in local mode. Then you can either use a skin with an EQ directly in your APP or you can pass a pointer for the equalizer object back from the skin into your application.
    You can also control visualizations through a similar method.
    Check out this newgroup post for more details
    http://www.msdn.microsoft.com/newsgr...6-eced67ce9e83
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by god_of_cpu
    I wasn't going to delve that far into it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Frodoplayer + WMP 10 = No Volume?
    By voidunknown in forum FrodoPlayer
    Last Post: 10-27-2004, 01:53 PM
  2. WinAmp viz's in FP (i.e. in WMP)
    By NoPistonPC in forum FrodoPlayer
    Last Post: 07-26-2004, 03:17 PM
  3. Gapless playback between MP3's in WMP embedded in VB6?
    By CRCinAU in forum Software & Software Development
    Last Post: 05-23-2004, 04:40 AM
  4. Question for Developers - Help find WMP bug workaround
    By GingerPrince in forum Software & Software Development
    Last Post: 01-14-2004, 02:52 AM
  5. Interesting Thing With WMP and VB
    By Bj in forum Software & Software Development
    Last Post: 10-08-2002, 02:10 PM
