Results 1 to 10 of 11
Thread: Converting protected/ecrypted wma's to mp3's
    Aug 2004
    Utah
    I ripped a whole bunch of cd's into my collection but now I am having the hardest time converting them from the wma format to a decent mp3 format. Anyone have any ideas on how to do this, I've heard its a kind of a PITA.
    Jan 2004
    Why do you need to change formats?
    Every time you change formats, you loose sound quality.
    Changing 96kbs WMA into a 192kbs MP3 isn't going to gain you any sound quality.
    Jan 2004
    I googled for an wma to mp3 converter, and found this http://www.dbpoweramp.com/
    It's pretty handy, ie it will do folders and sub-folders in one and will delete the original.
    You will probably need to download the wma codec from their site, but that is no problem.
    I then used musicbrainz tagger to tage them
    Pretty cool
    BTW I did this for the same reason as you, I ******* hate MS
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Quote Originally Posted by FunkDaMonkMan
    On the contrary if you change from .wma to .mp3 using the same bitrate (this is the key) you will never loose sound quality.
    If your changing UP bitrates then yes you will loose sound quality.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Jan 2004
    Florida
    Doesn't WMA have a better compression? So you would lose quality by going to the same bitrate MP3.
    Also, to convert from WMA to MP3 doesn't it convert to it to WAV first then to MP3?
    Oct 2004
    Birmingham,UK
    Anyone know of a good converter that will auto detect the bitrate of the file its converting and convert to the mp3 but at the same bit rate? i've used the one above and also another but both you had to set the target bitrate.
    Quote Originally Posted by sssssss27
    the quality shouldnt be any different, just the file size i think
    Install Status:
    |██████████|40% Complete
    FLAC jbors's Avatar
    Nov 2003
    In some cases mp3 may sounds better, in some wma at the same bitrate. But they use very different psyco acoustic models that makes comparison very subjective. So at the same bitrate you'll get very comparable audio quality with the same file size.
    Regarding 1:1 conversion I can send you a script that does that.
    Car pc integration with ease
    Car mediacenter
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    I think the more pressing issue is DRM. I think he wants to convert from a DRM protected file to a non-DRM file because he does not have a licence.
    Quick! To the Popemobile!
    Oct 2004
    Birmingham,UK
    I'm not sure what 91yjeeper is trying to do but none of the ones i want to convert are encoded. just plain wma's
    Quote Originally Posted by jbors
    If you could that would be great, if you want to email it my address is deanj @blueyonder.co.uk (without the space) or attach it to this thread. Cheers
    Install Status:
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    drm'ed file can't be converted back I thought.
  1. (slightly) skipping MP3s
    By Nav_Attack in forum General Hardware Discussion
    Last Post: 04-02-2004, 11:50 PM
  2. Edit mp3's........program to remove empty space??
    By guitar333 in forum Software & Software Development
    Last Post: 11-05-2003, 06:47 PM
  3. warbling mp3s
    By samael in forum Software & Software Development
    Last Post: 09-19-2001, 09:33 AM
  4. Will this decode mp3s
    By mprover in forum General Hardware Discussion
    Last Post: 10-24-1999, 10:29 PM
