Results 1 to 8 of 8
Thread: Missing system32/config.sys
    Low Bitrate PHiLiSO's Avatar
    Oct 2003
    detroit
    when i boot windows xp i get an error saying the config.sys is missing or corrupt, and it tells me to boot from cd and repair. I was wondering if any of you knew how to fix this problem without having to reinstall windows and all my drivers and stuff.
    How in the world would you put the special AirPort card in a PC? Mine is a Mac anyway but it's too old to AirPort. I just use a zip drive to transfer.
    Elsewhere
    Quote Originally Posted by PHiLiSO
    WindowsXP doesn't utilize a CONFIG.SYS. That's a throwback to the days of DOS.
    Whatever is telling you this is lying. I'd search anti-spyware & anti-virus websites for your solution.
    How about the Wiki?
    Illinois
    i got that a few time. a simple reboot took care of it for me though
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    is it saying missing system32/config? if it is, try booting from your XP cd go to the recovery console and run chkdsk /f that might clear up your problem
    肚子笑痛了
    S60 Install
    Belgium - Oostmalle
    Quote Originally Posted by DarquePervert
    This config is a map, not a file. Had this problem a few times. Still don't know what causes the problem. Doing a repair from the recoveryconsole (from the XP-cd) with chkdsk /f will indeed solve the problem. Good luck.
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
    Oct 2003
    detroit
    chkdsk /f isnt an option at all.
    Super Moderator xBrady's Avatar
    USA
    Are you at the recovery console?
    Installed.
    -GPSSecure- - GPS Tracking
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I have this a few time. Sometime a simple "Push a button" fixed the problem. Sometime, I have to reseat the memory.
    If you are working on the inside of the PC around the memory area and/or have the PC bump "drop/kick" or whatever that knock the memory loose, try reseat the memory.
    Most of the time that solve my problem with all the "missing file or corrupted" for no reason or no change in system files.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  2. Replies: 10
    Last Post: 10-12-2004, 04:43 PM
  3. What am I missing?
    By phatrabbitzz in forum Newbie
    Last Post: 07-27-2004, 10:10 PM
  4. IDE adapter without missing pin???
    By dank_Army in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:01 PM
  5. Replies: 15
    Last Post: 04-22-2003, 10:37 PM
