Results 1 to 10 of 16
Thread: Magnifying glass screen saver
    May 2003
    Anyone know where i can get that magnifying glass screen saver that came with WinME for winXP? I need something to prevent a burn in picture in my LCD, but still be able to see the screen for the most part.
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    ehm... LCDs do not well.. can not suffer 'burn in' that had (in the past) been associated w/ CRTs.
    No Charge
    •Micke
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    actually I have heard somewhere that it is still possible for LCDs to get burn-in of a sorts. But it takes weeks and weeks of constantly being on and on the same screen to happen. But not nearly as bad as CRT burn-in
    肚子笑痛了
    S60 Install
    May 2003
    i think LCD burn in easier than CRTs. I just want a screensaver nonetheless. Cause i see some minor burn in on my lilliput already.
    Jul 2004
    VaBch VA
    ok, I'm not in this thread to talk you out of a screensaver. you want one.. you get one.. sure sure.. but LCD's are MUCH LESS likely to experience burn in.. it takes HUNDREDS of hours. of the same image.
    While googling for your screensaver. also check "magnifying lense"
    •Micke
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    The LCD burn-in issue... Its not possible. Even new CRTs don't suffer from it unless turtured. If you search for Jurassic Park, you'll find a bunch of stuff on this.
    I don't know where you can find that screen saver though.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Raw Wave
    Jun 2003
    Strangely enough the TFT screen pixels do seems to go bad if it had been on for a while non stop.
    I have seen many "burnt" images on TFT screens. They were common on Compaq TFT500. They do dissappear after a few days though but annoying enough.
    I also have a permanent part image of IE on the top left of my old IBM TFT screen...this one never went away.
    ...just from my obeservation.
    Jan 2003
    Ruston, LA
    Let me find my CD, I'll grab the screensaver for you.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2003
    sweet! thanks!
    Jan 2003
    Ruston, LA
    Here you go.
    Attached Files Attached Files
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Question: Xenarc w/ts and screen saver
    By Tony S in forum LCD/Display
    Last Post: 04-06-2004, 04:16 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Redant screen - widescreen, screen res, TV out???
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-06-2002, 07:09 PM
