Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 106
Thread: Preliminary Testers Wanted - GPS Tracker
  1. #11
    Dec 2003
    looks good. can this also log the GPS coordinates? Also im sure many people want to have this running while they are running their norml GPS soft., is there an easy way to set up com port sharing?
  2. #12
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    will it work with a delorme earthmate gps?
  3. #13
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    My app is doing the relatively simple part, it is capturing the GPS data and writing it out to a file. The graphical part is all done using other services, the one above was generated at www.gpsvisualizer.com but I am aiming to use www.motionbased.com
    You can read and decide your preference but the latter is focussed on sports and tracking lap times and what they call "dot racing" where you race your own tracktime. They basically provide a cool interface and mapping of GPS data, primarilly captured from a handheld GPS (Garmin, Magellan etc).
    COM Port splitting - do a search, there are a few ways, COMFoolery is one that comes to mind.
    Delorme - yes, should work just fine, as far as I know.
    I'm trying to sort out some formatting issues in the GPX XML file at the moment, seems motionbased.com doesn't like my files!
    Chris.
  4. #14
    Nov 2003
    Massachusetts
    These tracks are based on a sample file but give a good idea on where I'd like this to end up, if everything works out. This is the same track displayed in three different ways at www.gpsvisualizer.com
  5. #15
    Oct 2004
    s.cali
    really cool, heres an urban one where i live, socal (the speeds are off cause its mph not kph) rather large sorry
    Progress: | All materials Purchased...
  6. #16
    Nov 2003
    Massachusetts
    Quote Originally Posted by BigToach
    really cool, heres an urban one where i live, socal (the speeds are off cause its mph not kph) <Image Removed> rather large sorry
    That's awesome, did you create the track with my app or another GPS? I ask because I realized last night I was tracking longitude a little off and needed a tweak to make it negative!
    What did you capture your track with?
    Chris.
  7. #17
    Nov 2004
    Hi, I'm the author of GPS Visualizer. Often, speeds don't plot properly from GPX files that were created by early versions of programs because the people who create the programs don't realize that the GPX specification calls for the speed to be represented in meters per second (and elevation should, of course, be in meters).
    So, ukchris: m/s, please!
  8. #18
    Nov 2003
    Massachusetts
    Whoa, just the guy we need here, thanks Adam!
    At the moment I have my results loading into your app pretty well, albeit with the units a little messed up but I can fix that later. The GPX spec is sending me a little nutty with another service though where it rejects my GPX files as invalid, they offer a similar service (www.motionbased.com) but specialize in comparing tracks and displaying graphical data linked to the track at the same time for reference.
    Great job on GPS Visualizer by the way!
    Chris.
  9. #19
    Nov 2003
    Massachusetts
    Update, just posted a new exe at www.lawlai.com/mp3car/GPSTracker.zip
    Only two minor changes, the speed should be in m/s now so it should represent okay at GPSVisualizer, also it is inserting a "-" before the Longitude which I needed for East Coast US. I need to sort out when it needs to be negative and when it doesn't and fix this properly.
    Chris.
  10. #20
    Nov 2004
    What's the issue with negative longitudes?
  1. wanted deluo usb gps
    By l4tran in forum Classified Archive
    Last Post: 05-07-2004, 01:12 AM
  2. Gps Wanted [help Needed]
    By tommy10uk in forum GPS
    Last Post: 04-19-2004, 12:55 AM
  3. Wanted: NMEA GPS receiver
    By CarComp in forum Media Engine
    Last Post: 03-25-2004, 04:38 PM
  4. Wanted: Controller, PSU, GPS...
    By claylong in forum Classified Archive
    Last Post: 03-21-2002, 01:02 AM
  5. GPS wanted
    By mp3pc in forum General Hardware Discussion
    Last Post: 02-08-2001, 01:17 PM
