Try opening all of them and seeing if you see any GPS cordinates 32.87711208 or something like this....Originally Posted by muldrick
I was told that the Toyota DVD Navigation disc is a generic map dvd disc.
The Australian DVD Disc has the "Sensis" logo on it and more info is at http://www.about.sensis.com.au/whereis/
and according to that URL "BMW, Mercedes Benz, Lexus and others" use these Sensis Discs, although it might be different in the USA.
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
While it's true that many packages use Navtech data, it's also true that Navtech typically delivers the data in whatever format their customers' specify. This means that it's generally not possible to move data files between GIS software (without some conversino).
I suspect that the various files you see are probably metadata and/or index files to assist the OEM software to more quicly process the ALLDATA.KWI file. Moreover, it's likely that ALLDATA.KWI is compressed (or at least contains compressed data fields). Do an ASCII filter of that file. That should quickly tell you if there's any hope of extracting the POI info you want.
@0l33l: don't you think the lat/lon info will be binary encoded IEEE floating point instead of ascii encoded (assuming for the moment that compression isn't an issue)?
It's already been done, its not worth it. The mapping software that we use in PC and Car generally baught map/data from a different company, most likely "Navteq" then programmers plug the maps, they baught, in to thier software. Check This Out
That link brings you to an active x control, designed to show raster based maps. You can buy the control... all you need it raster based maps. Check Here For maps
Generally, the maps we all use weather thier in PC,PDA,WEB BASED,CAR NAVIGATION are all the same they come from the same place, the only difference is the software running on top of the maps...
And yes, there is converstion software already design... Check out the US GIS (Geographic Infomation Service, I think ?) web site, they have a software development section that explains in DETAIL how to convert these maps.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
You all are talking way over my head, I know nothing about this. However, I don't see how these are the same maps, they look entirely different and more acurate too me.
Anyhow, I'm at work now, nothing much I can do. I am working on getting the latest Lexus software with 11 million POI's and even "prettier" maps. Should have it Monday (maybe tonight). Maybe we (you guys) should study that instead? (since it's the latest version)
EDIT: Got It!!!
Same type files...screen shot next post (deleted)
EDIT AGAIN: I only got the latest Version of generation 3, which is still the same as what I showed before.
I am going to work on getting the Gen.4 dvd, I hope someone can pick it apart. It's got what HD was talking about in post#8 and it's got the 11 million POI's.
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
anybody?
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
Yo, can u take some pictures of the NAVI in action? I want to see if it looks like what I think...Originally Posted by muldrick
I heard from someone that the latest NAVI disk contains street layouts (i.e. building shapes, parks, bodies of water, etc.
Thanks!
-HD
well i have a copy of arcview if that helps anyone
