Results 1 to 10 of 12
Thread: LCD Font
    Maximum Bitrate DjBac's Avatar
    Jun 2004
    GREECE/Athens
    LCD Font
    Does anyone know where I can find an LCD font? Like the one the calculators have?
    I want to display the time as a 7-segment display on the app I am writing for the car's main controls!!
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Here a link where you can find some fonts you might like. They have alot of fonts.
    http://www.fontscape.com/explore?5K4
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jun 2004
    GREECE/Athens
    Thanx!!!
    Dec 2003
    New York
    no problem.
    Installed
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Here are some good LCD fonts
    Attached Files Attached Files
    We are, will have and forever will be...
    But not tommorrow!
    Jun 2004
    GREECE/Athens
    That's great!!
    Thank you very much!!!
    Could someone recommend me a way to display time-date with visual basic?? I am having some problems...
    Oct 2004
    UK
    =date() or =time() as the text property of the text boxes
    Jun 2004
    GREECE/Athens
    I've tried that but the time won't update!!!
    This is why I used timers instead!
    Thanx though!!
    Jul 2003
    Quote Originally Posted by DjBac
    Thanx though!!
    Use the format function.
    Code:
    Format(Now, hh:mm:ss)
    This was off the top of my head, i may be wrong. 'Now' returns the string of current date and time, the format function formats it in the way you wan to display the info. I believe for date its "dd/MM/yyyy". You can also use 4 M's to get the full title of the month. You will need to use a timer to kep it up to date.
    But not tommorrow!
    Jun 2004
    GREECE/Athens
    Well I did use a timer for the time, it seems I will have to do the same for the date!!
    Is it possible instead of 15:46 to display 3:46 ?
  1. Replies: 13
    Last Post: 12-24-2005, 06:14 PM
  2. Lilliput LCD monitors
    By 001 in forum LCD/Display
    Last Post: 10-27-2003, 03:46 PM
  3. lcd datasheet help
    By oddcomp in forum LCD/Display
    Last Post: 11-08-2002, 11:24 AM
  4. Replies: 5
    Last Post: 08-20-2002, 09:32 PM
  5. Replies: 2
    Last Post: 07-16-2002, 09:15 PM
