Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Cabin Control v1.0
    Feb 2004
    Cabin Control v1.0 - Phidget Interface
    Hello gang,
    I wrote some software for my car project called Cabin Control and what it basically does is interface to a Phidgets 8/8/8 Interface board to control temperature inside of my computer case. For example, I have a temperature sensor in the cabin area of my car and one inside my case. Based on the temperatures inside the case and outside, my software will control two DC fans to blow air out of the case or blow air inside the case. I.e. if its summer it will most likely exhaust the air, in the winter it will mostly take the air from the cabin as it warms up.
    I also use it to monitor the voltage of the battery and I have a dual axis accelerometer to monitor tilt. This is more of an experimental/info gathering then for practical use, but I thought I would see if people are interested in it. I've basically custom built it for my own use but I could make it more generic, skinnable and configurable from a ini file if some people wanted it.
    Jun 2003
    Memphis - TN
    thats pretty slick
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Feb 2004
    Thanks! There are a ton of potentially cool things you could use phidgets for in a car project. Especially the relay board. I basically want to be able to troubleshoot/have proper info if/when something happens. I.e. low voltage, extreme cold, extreme heat.
    Constant Bitrate ncamara's Avatar
    Dec 2003
    Hampton, VA
    Quote Originally Posted by King_Aero
    Keep up the good work. Those phidgets seem to be very versatile, lots of different applications for it.
    Installation Complete, pics soon
    EPIA M10000 in Morex 3688 case
    FrodoPlayer
    CoPilot Live 8
    Back from long hiatus, will be rebuilding soon
    Feb 2004
    In the end, I don't see the "Control Status" interface looking like that, because the raw sensor values are useless to people and myself. Its more or less a debugging tool for now. I'll likely replace it with some visualizations for the dual axis sensor.
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    That's pretty sweet! Please make it skinable.
    It's the cake having/eating thing.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    What language is it written in?
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    ( Sorry ) whats a phidgets ?
    Terran
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    www.phidgetsusa.com
    There a seller of general purpose PC controlled I/O cards with various analog / Digital inouts and relay outputs
    pretty impresive boards, but pricey unfortunalty.
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Feb 2004
    Quote Originally Posted by 0l33l
    Its probably not what you would expect it to be written in but its a MFC Dialog based application written in C++. GUI applications and higher level programming languages like VB are not my most skilled area. I'm more of a low level C programmer. I think there will be some limitations to using what I did, but it has gotten the job done so far.
  1. Voice control for Winamp
    By VoodooVoice in forum Software & Software Development
    Last Post: 08-01-2006, 05:19 PM
  2. My LPT Relay Control Software
    By wizardPC in forum Software & Software Development
    Last Post: 02-13-2005, 12:10 PM
  3. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  4. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-03-2003, 11:00 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
