Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Windows XP Hibernating Problems
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    HI well this is funny . wonder if any of u had this problem while hybernating XP
    Well I have HIbernation active on my comp..and IT DOES hibernate properly.. but the problem starts when it has to come out of HIBERNATION...Give this error
    "" The system could not be restarted from its previous location due to read failure """
    and then it give an option
    "" DELETE restoration data and proceed to system boot menu ""
    When i hit this option the computer starts normaly and is not the restoration oh hibernation.....
    CAN some one help PLS.. cos hibernating will reduce a considerable booting time
    thanx
    vicky
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I've experienced this problem when my WiFi and BT USB dongles are plugged in at boot time...
    John
    Low Bitrate IonDokk's Avatar
    Michigan
    I had to switch to an older power supply from morex and ever since i get these same errors.
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
    Variable Bitrate Batmanatthenewb's Avatar
    Sep 2003
    Newark, Ohio
    I have had this problem two or three times over the last year. Seems to come up when the computer isn't shut down correctly for me. Ater I rebooted and shut back down worked fine, just the hibernation file was damaged. After running scandisk (marking bad sectors and fixing errors) and defrag have had no more problems.
    Batman
    Batman@TheNewBatcave.com
    AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
    www.samshomepage.net
    www.Cars-N-Computers.com
    Dec 2003
    Thanx friends but in my case there is no change of PS or any BT. Its just plain P4 comp and 512 mb ram . and i have checked the HD also no sign of BAD sector or error. SHut down is perfect and so is HIBERNATIOn its only that the restoring from HIBERNATION is MESSING things...
    any more suggestions ....PLS
    thanx cheers
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    Jul 2004
    what type of powersupply and shutdown controller are you using? I have a Morex case w/built in 60w PS and a Carnetix P1260 and I was experiencing the same thing. I found that the Carnetix was shutting off power to the pc just a tad prior to hibernation finishing completely. I had to change the setting on the Carnetix to 90 seconds and now it works great.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I have had this problem... i get this when my usb flash drive is plugged in when i go into hibernation. Try unplugging usb devices.
    Does it happen everytime?
    Dec 2003
    Well I am using a P4 2.4 and 512 MB ram
    ANd no USB are connected. Its all just RAW. no add on devices as of now.
    and since i am redoing the lilliput indash thing the comp is back in my work shop working on normal 300W power supply on mains. and so theres no shutdown conttroller as of now but am planning to get
    1.....PW200M Cableless EPIA-M power supply. ( X 2 ) so that i can use in parallel for extra wattage from http://www.mini-box.com/s.nl/sc.8/ca...it.A/id.300/.f
    2.....Dashwerks Startup and Shutdown Controller (DSSC™) from http://www.dashwerks.com/dw_dssc.php
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    May 2005
    Unhappy read failure
    i'm getting the same problem... whenever i hibernate my XP laptop, it comes up with the system read failure error, either that or the blue screen of death... this started happening as soon as i downloaded the latest Windows Update -- Windows Installer 3.1... when i removed the update (from add/remove programs) hibernating worked fine, but it keeps automatically downloading the stupid thing, and it's obviously supposed to be important... so i could just keep removing it (i tried stopping it downloading all the time by hiding it in the updates, but that didn't work), or just let it be, but i really need hibernate!!!
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    why dont you just disable automatic updates after you uninstalled it ??
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. Windows XP
    By milleda31 in forum General Hardware Discussion
    Last Post: 04-02-2004, 03:19 AM
  3. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
  4. Rand McNally GPS, Street Atlas Deluxe, and Windows XP...
    By Defiler in forum General Hardware Discussion
    Last Post: 09-18-2002, 07:46 PM
  5. Adding "Sound Events" to Windows XP...
    By Defiler in forum Software & Software Development
    Last Post: 03-13-2002, 10:59 AM
