Results 1 to 10 of 11
Thread: Ram and hibernation
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    Ram and hibernation
    So, obviously the less ram you have, the faster your Hibernate times are gonna be.
    but here's my question.
    Does Ram speed matter when it comes to Hibernation. Will a PC3200 outperform a PC2700 in boot-up times?...
    and by how much? (guestimates accepted)
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Feb 2004
    Charlotte, NC
    anyone...? anyone?
    Low Bitrate l0gic's Avatar
    Essex - UK
    Any memory is going to be faster than the transfer speed of a HD.
    So I'd say that the write speed of the HDD is going to be the bottle neck, along with the amount of memory to write.
    Kevin
    Build status {..........|} 99%
    All installed - now into the fiddling about stage
    Car:MR2
    MB: EPIA C800
    Display:Xenarc 700TS
    Power:PW-70A & ITPS
    Mem:384MB
    HDD:40Gb Maxtor Diamond max
    Radio:Dlink DRU-100
    GPS:BU-303
    OS:XP SP2
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Your talking about miliseconds between the two types of RAM....
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Maximum Bitrate knubile's Avatar
    I don't think less ram hibernates faster. It's a matter of how much ram is in use. I had a 512 stick, but only 180megs being used. My hibernate was taking too long for my system, so i switched it for a 256 stick. It made no difference at all.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Hibernate will take up the ammount of ram, weather it is filled up or not, and the size of the swap file. So the less tham the better for fast boot, esp. since you don't have to check all of it.
    Agreed it takes up the same amount of space as ram. But I think that the space is just reserved for the hibersys file. I don't think it actually writes the full 512mb of ram during hibernation.
    That the only explanation I can come up with for it notting hibernating any faster when the amount of ram is halfed.
    Remember, my system wasn't using more than 256 in the first place. This would obviously not apply if more than 256mb of ram was actually being used in the 512 stick scenario.
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    I highly doubt it will write the whole 512 Mbytes if you have that much ram. It takes a couple of minutes to write a file that big.
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by l0gic
    Exactly. Try getting a faster hard drive if you want faster speeds.
    Installed.
    -GPSSecure- - GPS Tracking
    Feb 2004
    Charlotte, NC
    like how much improvement would a faster hardrive give me in general?
  1. Problems Enabling Hibernation
    By divinity in forum Software & Software Development
    Last Post: 05-16-2004, 01:03 PM
  2. How fast can restart from hibernation happen?
    By Mastiff in forum Software & Software Development
    Last Post: 01-15-2004, 10:40 PM
  3. XP hibernation doesn't work
    By nicgalla in forum Software & Software Development
    Last Post: 08-03-2003, 10:18 AM
  4. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:40 AM
  5. Windows Me hibernation
    By rsriverrat in forum Software & Software Development
    Last Post: 09-06-2000, 07:10 AM
