Results 1 to 5 of 5
Thread: Some help with generic software....
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Ok, I have a program that reads cpu usage via the taskman and it outputs to the serial port to drive a automotive style tachometer. The program itself works nice, loads on startup and no problems...except...
    it leaves the taskman "window" open, and has 2 buttons, hide and exit. Every time the pc starts up, i need to click hide. There has to be an easy way to bypass this any thoughts?
    2005 Ford Focus ST
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    r'click the icon for this. select open minimized
    •Micke
    Nov 2004
    Add the following Registry Key
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run
    Give the REG_SZ value the name TaskManager and then give it the following string:
    start /min c:\\windows\system32\taskmgr.exe
    This will start it mimized and you won't have to worry about it.
    Dec 2003
    Portland, OR
    Thank you for the quick advise! Helps a ton. Minimized is great....still wish I could manipulate the "hide" button though
    2005 Ford Focus ST
    Nov 2004
    if all else fails, look up the program autoit. its pretty nice for many things, it works by manipulating the mouse/kb amoung other things.
  1. Suggestion for the Software forum
    By Confused in forum Mp3car Forum Suggestions/Comments
    Last Post: 11-02-2004, 08:55 AM
  2. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  3. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
  4. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 11:30 AM
