Results 1 to 9 of 9
Thread: Mame Gurus, question regarding nag screens
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I'm using Mame32K in the car and i was wondering if there was a front end program i could run that would get rid of the rom notification (hit select) screen and the press ok screens. Its kinda a pain to have to pull out my keyboard to start a game when i'm using joysticks to play it.
    Feb 2004
    Green Bay, WI
    you should be able to configure the controller to do that....like have the start button or a trigger you don't use do it.....
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    Yeah I've been searching for that as well. Light of running every rom and pressing "o k " " any key." Also does anyone have any new good mame roms?
    Mine needs to be updated.
    Jun 2004
    Whatever input you are using, just go left right left. That will get you past it. Also There is a way to disable the disclaimers but not error messages, but again, left right left should get you past those.
    Woodbridge, VA
    Blog Entries
    55
    left right left no worky for me. Least on the "select button" screen on my laptop. I'll try it in the car with my joysticks on the way home tonight
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    whoa it acutally works, thanks bangster. so anyone have any new roms?
    I haven't even touched my 1800 roms because of that friggen type ok.
    Woodbridge, VA
    Blog Entries
    55
    newest i've got is marvel vs. capcom lol
    Constant Bitrate e_z_street's Avatar
    Feb 2004
    If you download the source, you can disable the nag screen code and then compile.
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    use the dos version then u can set it to disable the nag screen
    it will only but a tad slower when loading roms like metal slug but its worth it
    u could just download an unoffical version which has nag screen removed and the new metal slug 5 game enabled
    have a look at this thread: NES ROM Frontend
    Gives u an idea on how i have mame and other emus setup to be played and selected by just the game pad
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  1. XBOX, Carputer, power Question! ELECTRIC GURUS HELP!
    By EggrollXpress61 in forum General Hardware Discussion
    Last Post: 08-21-2004, 12:15 AM
  2. Question: reguarding Those composite screens
    By djliquidice in forum Newbie
    Last Post: 10-12-2003, 09:43 AM
  3. Cable Question for the LCD Guru's
    By xanimal in forum LCD/Display
    Last Post: 06-24-2002, 05:18 PM
  4. Another inverter question...for electronics gurus
    By moahdib in forum Power Supplies
    Last Post: 06-07-2001, 09:30 PM
  5. newbie question..laptop screens
    By InAFocus in forum General Hardware Discussion
    Last Post: 08-23-2000, 11:15 PM
