Results 1 to 8 of 8
Thread: Firewall/Port Blocking - GPRS
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I'm looking for a firewall (or similar) that I can use to block all outbound access from a PC by port, such that I can say only Ports 80, 25 etc can be accessed.
    Ideally I'd like different blocking on different network / dialup adapters.
    The reason is that my GPRS service chanrges for some ports but not others. I've been trying a freeware firewall but it doesn't allow port selection, seems to block only by application.
    Chris.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Pretty sure the new firewall in XP SP2 can do this, plus you can have different settings for each network adapter
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Nov 2003
    Massachusetts
    I believe it only blocks inbound traffic, no outbound control.
    Raw Wave
    Jun 2004
    On the beach
    TCP/IP Properties, Advanced button, options,, click properties, tick enable TCP/IP filtering and enter only the ports you would like enabling by choosing permit only under the TCP Ports and enter the port numbers.
    Be aware that this will only work in XP or 2000.
    Hope this helps - saves clogging up carpc with unnecessary software :-)
    Nov 2003
    Massachusetts
    Looked promising, but it seems to only be there for the network adapters, not for dial-up adapters such as the Bluetooth connection I'm trying to restrict though. Thanks though, nearly but not quite!
    Raw Wave
    Jun 2004
    On the beach
    Ah k - not using bluetooth yet, and only got LAN on this machine .... will have another think - can't be too difficult to implement.
    Nov 2003
    Massachusetts
    About to try the Sygate free firewall, see if that'll do it.
    Nov 2003
    Massachusetts
    Looks like the Sygate personal firewall will do it, with advanced rules you can block port ranges by individual adapter, still testing it with two NICs but it looks promising, have to try dial-up next.
  1. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  2. o2 GPRS Pay as you Go (UK) might be free
    By stevieg in forum Wireless Communications
    Last Post: 11-28-2006, 08:11 PM
  3. What's the ideal web browser over gprs?
    By M^ck^y in forum Wireless Communications
    Last Post: 11-20-2004, 03:59 AM
  4. USB GPRS Devices?
    By Nico3k in forum Wireless Communications
    Last Post: 10-09-2004, 10:14 PM
  5. Replies: 9
    Last Post: 02-09-2004, 02:34 PM
