Results 1 to 6 of 6
Thread: WINDOWS XP limitation or what?????
    Jul 2004
    Line in and Mic Simultaneously!! HELP
    Ok I search and I couldn't find anything on this matter.
    I am running Media Car 1.9, with the USB FM radio. The radio is normally connected to the Line-in, which is chosen as the recording device in the volume properties. That work perfectly. The MediaCar plays and shuts down the radio, when entering and exiting the radio module. Now I also have Zooro's Phone control and plan to add maybe NaviVoice. Now here is the problem. Since Line-In (occupied by USB radio) is selected as the recording device, the mic can't be ( its either line-in or the mic). Beacuse of this my mic is not used by these applications (Phone Control ,or should I say Widdcom's Blutooth headset profile). Anyone has any idea how I can solve this. or is it solve-able. I sure someone has both things running without the need to swicth the recording device every 5 minutes ? help
    Jun 2004
    Latvia
    Use Mix instead of single device for your recording device... its simple... In properties of recording mode you should be able to enable 'Stereo Mix', 'Mono Mix' or simly 'Mix' or 'Mixer' as aditional slider like those for your 'Mic', 'Line-In' or 'Wave'. Then use it!
    Jul 2004
    Thanks Nufis, I am at work right now , but I will try that ASAP
    Jul 2004
    One thing that I remeber though is that Media Car controls the radio by mutting/unmutting the Line-in input on playback. If I switch the recording device to stereo mix, will the mute work. As far as I know there is no mix option on the playback.
    Jul 2004
    Stereo mix doesn't do the trick
    I tried setting record device to stereo mix and mono mix, but as soon as I it, the radio input goes into a loop. The mic can be heard, but the line-in goes nuts.
    Does anybody have a radio and phone control (or any mic application) working fine and how??
    Jul 2004
    Anybody???
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  2. epia M 10000 AND WINDOWS XP PRO
    By Dluvr22 in forum Software & Software Development
    Last Post: 10-18-2005, 09:04 AM
  3. Replies: 11
    Last Post: 10-08-2004, 08:59 PM
  4. windows 2000, xp and EPIA 800
    By samc in forum General Hardware Discussion
    Last Post: 08-24-2003, 09:41 PM
  5. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
