Results 1 to 9 of 9
Thread: XP desktop icon question
    _
    Mar 2004
    Little Elm, Texas
    Ok - let me see if I can explain this. You know how on previous windows operating systems your desktop icons didn't have a transparent background for the text. Well recently my home computer which is running XP has gone from having the transparent backgrounds on the text to no longer having the transparent background. Does anyone know what causes this and if there is any way to put it back to being transparent?
    Jan Bennett
    May 2004
    NJ
    Did you try to reset the icons by setting them to "large" then back again to normal size, that might do it but I am not sure, worth a try though. (desktop>property>appearance>effects>check large icon>OK)
    Constant Bitrate b_nom's Avatar
    Houston, TX
    Talking
    actually go to start>settings>control panel>system and go to the advanced tab, click on settings for "performance" and in the "Visual effects" tab look for "Use drop shadows for icon labels on the desktop" or just select "adjust for best appearence" but if your computer is not fast enough it may slow down (I'm talking about older ~650mhz CPUs and below).
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Houston, TX
    As to why this happened (one day being there and the next one it was gone) it could be that "let windows decide" is chosen on that same "visual effects" tab which depending on the performance of your computer maybe windows removed the setting to save a couple of CPU cycles.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It can also do that if you use an active desktop wallpaper, so make sure you're using just a normal image.
    Maximum Bitrate nFiniteTuning's Avatar
    Albuquerque, New Mexico, United States
    Yeah, if you installed a specific wall paper, Active Desktop will be enabled, so then bye bye transparency. If you knew about changing the visual/performance settings, then you would know if you turned off transparency in the area b_nom said.
    -Josh
    1997 Mitsubishi Eclipse GSX
    My URL: https://www.facebook.com/jagray85
    XBOX: DarkerStars
    Feb 2004
    NYC
    Quote Originally Posted by Curiosity
    normal as in BMP right? I think if you use JPG, it's consider Active desktop
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    im using a JPG file as my wallpaper and I have the fonts on a transparent background like he wants
    Mar 2004
    Florence Yall, BFKY
    JPG seems to be fine. There used to be one in XP that was an active desktop kind, but I can't find it anymore. I know if you drag a .html file into "My Pictures" you can use that as a wallpaper and the icon text will be non-transparent (and slow everything down).
  1. xp remote desktop connection?
    By icet in forum General MP3Car Discussion
    Last Post: 09-02-2004, 10:53 AM
  2. are there similar xp media player desktop
    By inniss777 in forum Software & Software Development
    Last Post: 11-05-2003, 05:43 PM
  3. just reinstalled WinXP......have one question..need a little help.
    By guitar333 in forum Software & Software Development
    Last Post: 10-15-2003, 06:34 PM
  4. icon question
    By robert42 in forum ME Archive
    Last Post: 09-07-2003, 07:49 PM
  5. desktop icon text shaddows & color in xp
    By ShinkunoNamida in forum General MP3Car Discussion
    Last Post: 01-30-2003, 02:33 AM
